fuel tank size - JeepForum.com
post #1 of 7 Old 09-27-2012, 02:31 PM Thread Starter
wtroger
fuel tank size
1998 jeep TJ 2.5L 5 speed built date 7-97 need to put a fuel pump in it. How do i determine fuel tank size. I have searched 17 different ways and cant get a hit. I know this has been discussed before. Vin decoder says 15 gals not sure I can trust that.
wtroger is offline
post #2 of 7 Old 09-27-2012, 02:50 PM
mg2380
Question: Have you ever put more than 15 gallons worth of fuel into your tank?
mg2380 is offline
post #3 of 7 Old 09-27-2012, 02:54 PM
TheRealKTrain
JK Wrangler
That response made me ROFFLE
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #4 of 7 Old 10-01-2012, 05:36 AM
mdm
Farm Wheeler
Several times I put more than 19 gallons in my wife's '05 19 gallon tank.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #5 of 7 Old 10-01-2012, 06:42 PM
Threesticks
Check the part number
There is a part number on the lower drivers side out board.
52018 687AB for the 15 gal and 52018 768AB for the 19 gal.
http://www.jeep4x4center.com/jeep-pa...ts-Catalog.pdf
Threesticks is offline
post #6 of 7 Old 10-01-2012, 06:47 PM
biffgnar
biffgnar's Avatar
Yep, BTDT. And isn't the 15 gallon tank really much bigger with just a long fill neck? Park the jeep at the pump with the rear higher than the front and you could probably get a lot more than 15 gallons in.
Romney in 2020!
biffgnar is offline
post #7 of 7 Old 10-01-2012, 09:40 PM Thread Starter
wtroger
Swapped fuel pump today. Used a 15 gal pump module seemed to match the one in there. Not to bad a job comes straight down worst part was getting the hold down ring to unscrew. Thanks for the input folks.
wtroger is offline
Fuel Tank Size? qlfarm YJ Wrangler Technical Forum 3 09-24-2011 12:14 PM
fuel tank size rwest12396 TJ Wrangler Technical Forum 5 02-18-2011 12:18 PM
Fuel tank size? Maverickxeo TJ Wrangler Technical Forum 15 08-13-2010 11:44 PM
Fuel Tank Size Raxmar TJ Wrangler Technical Forum 2 08-02-2006 08:10 PM
what size fuel tank do i have? chrispaul YJ Wrangler Technical Forum 10 05-02-2004 10:39 PM
