Fuel Tank Options for stretch or more room - JeepForum.com
post #1 of 75 Old 03-25-2009, 10:01 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I'm looking to gain some more room under rear end. For now for rocks and later a stretch.
I would like a genright tank, but that's more money than I want to spend so I'm debating a fuel cell.
My idea is to put one behind the rear seat but recess it into the floor where the bottom of the tank is roughly even with the frame rails. I'm also going to build a box around it so that it helps to seal out any fumes.
What all needs to be done to do this.
tank, fuel lines, is it possible to retrofit the factory pump?, steel for a custom skid, something to reinforce the rear frame where it a cross member may need to be taken out.
I know I would lose storage, but I would gain room underneath the jeep. The rear seat hasn't been in over a year and my spare tire has been in its place. I want to be able to run a back seat if I need to.
Any thoughts or ideas.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #2 of 75 Old 03-25-2009, 10:07 PM
never monday
I think RCI makes on the sits behind the seat and accepts the TJ pump unit.
never monday is offline
post #3 of 75 Old 03-25-2009, 10:12 PM Thread Starter
JeepRocks86
ok, i've heard that. Couldn't remember the brand.
This one maybe?
15 gallon 12" high, 30" long, 9" wide
http://store.summitracing.com/partde...5&autoview=sku
17" high, 30" long, 7" wide
For Sale:
post #4 of 75 Old 03-25-2009, 10:15 PM
never monday
I've seen those used. But theres one out there that takes the TJ pump module. Might search the PBB
post #5 of 75 Old 03-25-2009, 10:18 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
there was thread on PBB where guy did this using factory tank, saved money and weight
RnEmOvr is offline
post #6 of 75 Old 03-26-2009, 08:50 AM
bradleyfitz
RC2161A. Get some rings for your pump from K.O.R.E. They also sell an install kit with SS lines.
Genright also has fuel cell rings.
98 Sahara, hp44/hp60, warn 5x5.5 premium hub conversion, 4.88, arb's, hydro assist, RE 4.5 SF /w 3.5 springs, Novak / Teraflex SS SYE, currie anti-rock, JKS 1.25" BL, 36" bias iroks, PSC Tube fenders /w 3" flare, PSC Ricochet Rockers, custom rear bumper, btf front bumper / winch plate, warn 9.5ti, full cage, TwistedStitch seats, RCI-2161a fuel cell
bradleyfitz is offline
post #7 of 75 Old 03-26-2009, 09:04 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
What is that RC2161A number you provided?
I Googled it and nothing came back.
Wheelin98TJ is offline
post #8 of 75 Old 03-26-2009, 09:11 AM
bradleyfitz
Technically RCI 2161a. This is the fuel cell most people swap in behind the rear seat. 15 gallons.
post #9 of 75 Old 03-26-2009, 09:16 AM
Wheelin98TJ
JEEP FREAK
Thanks.
I thought it sounded familiar, but I was drawing a blank.
post #10 of 75 Old 03-26-2009, 09:43 PM Thread Starter
JeepRocks86
so I could get the RCI tank and then a ring and it would bolt up to the factory pump with extensions?
It can't be that easy.
For Sale:
post #11 of 75 Old 03-27-2009, 09:40 AM Thread Starter
JeepRocks86
from a one ton build up...
Originally Posted by tweba99 View Post
I went with the Summit RCI cell behind the rear seat. It cost me the cell, kore4x4 cell ring, a couple of fittings and some fuel injection hose. All less than $300 from what I remember. Worked great.
For Sale:
post #12 of 75 Old 03-27-2009, 12:54 PM
lupinsea
lupinsea's Avatar
I can't remember where I saw it but:
Someone posted a write-up for re-using the factory 19 gal. fuel tank, pump, etc. They cut a hole in the floor of the TJ's cargo area and raised the stock gas tank up enough that it poked about halfway through the floor. Then they fabbed up some mount system for the stock skid/straps to attach to either the body or chassis.
If you don't mind cutting your body it seems this would be an economical way to go. Not to mention you'd get a fairly large gas tank vs. the 15 gal fuel cells.
- Jay
lupinsea is offline
post #13 of 75 Old 03-27-2009, 05:40 PM Thread Starter
JeepRocks86
That would work, or I could even just put the tank in the back of the jeep, but I want to be able to run a back seat too.
For Sale:
post #14 of 75 Old 03-29-2009, 03:23 PM Thread Starter
JeepRocks86
Anyone have a parts list with part numbers?
For Sale:
post #15 of 75 Old 03-31-2009, 10:49 PM Thread Starter
JeepRocks86
any lists?
For Sale:
7" Rear Stretch - Options and the $$$ ?? Airdoc TJ Wrangler Technical Forum 26 11-18-2009 09:05 AM
Help: In tank fuel pump options? Fred007 YJ Wrangler Technical Forum 1 05-13-2009 07:20 AM
re la kit and stretch options? MODUS TJ Wrangler Technical Forum 2 01-02-2008 04:33 AM
Fuel cell options for rear stretch martells2 YJ Wrangler Technical Forum 17 02-23-2007 09:50 AM
options to stretch...plus coilovers... BigWaylon TJ Wrangler Technical Forum 185 11-29-2006 08:36 AM
