fuel rail schrader valve? - JeepForum.com
post #1 of 4 Old 01-03-2007, 10:12 AM Thread Starter
tommygdbr
where on the fuel rail is the schrader valve located? I need to check it but can't find it- hard to look when it's 20 degrees outside!
97' TJ- 2.5-5spd
Bestop Sailcloth Top
30x9.5 BFG ATs
tommygdbr is offline
post #2 of 4 Old 01-03-2007, 10:22 AM
geauxturbo
geauxturbo's Avatar
Few inches back down the rail from the injectors (just follow along the fuel rail from the injectors). Has a plastic cap on it like your valve stems on your tires. Kinda hard to miss. But, I have no clue what 20 degrees is like.. maybe your eyeballs will be shivering
'97 TJ Sport Black, 3.5" RE, PSC Trail Cage, Ford F150/Explorer Hybrid 8.8 Aussie locked, Lockright in the XJ HP 30, 4.88 gears, Borla Headers, No Muffler, 35x12.5 R15 Baja MTZs, Currie TrackBar. Homebuilt Longarm 4 link, AA HD SYE, TW CV DS, Warn tire carrier, Jeeperman front bumper, Warn X8000i with Amsteel Blue rope with a safety thimble, CO2
geauxturbo is offline
post #3 of 4 Old 01-03-2007, 10:22 AM
Dogman
Dogman's Avatar
I've heard it reported that some 4 cylinders don't have one. But, here is a shot from the '98 FSM.
John 3:17
Dogman is offline
post #4 of 4 Old 01-03-2007, 10:34 AM Thread Starter
tommygdbr
You guys rock
97' TJ- 2.5-5spd
30x9.5 BFG ATs
Fuel rail pressure relief valve leaking ....what to do? mrbruce88 TJ Wrangler Technical Forum 17 03-21-2011 06:00 AM
Where is the Schrader valve? sixclicks TJ Wrangler Technical Forum 10 06-23-2008 09:46 PM
Schrader Valve jwilliams TJ Wrangler Technical Forum 20 11-17-2006 08:08 AM
Exhaust Manifold Help : Lost on how to remove Fuel injectors, wiring, and fuel rail. Mr. Notorious YJ Wrangler Technical Forum 9 08-10-2005 06:00 PM
Replaced fuel pump & no gas to fuel rail Part 2 BrianBC YJ Wrangler Technical Forum 0 08-24-2004 07:20 AM
