Fuel rail leak at the injector - JeepForum.com
post #1 of 4 Old 07-09-2010, 12:53 AM Thread Starter
camsthorpe
So, my 2003 Tj just started leaking where the fuel rail connects to the #3 injector. It looks to be right at where they clip together. Any ideas on what exactly is causing this? Is it the injector, fuel rail, or an o-ring of some kind that needs to be replaced?
camsthorpe is offline
post #2 of 4 Old 07-09-2010, 12:30 PM
BigRed52
bump
1996 ZJ 5.2L, 3.5 IRO F>R, 15" Soft 8's, 249>242 swap
Utah JeepCrew #17
BigRed52 is offline
post #3 of 4 Old 07-09-2010, 01:00 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
I would suspect the o-ring.
Remove the injector and see if the o-ring is torn or if its dirty around that area causing it to not seal properly.
You'll need to depressurize the fuel system to do this.
The unsafe way - push the schrader valve on the fuel rail and let the fuel squirt out.
The safe way - pull the fuel pump relay under the hood and let it run itself out of gas.
Wheelin98TJ is offline
post #4 of 4 Old 07-09-2010, 09:32 PM Thread Starter
camsthorpe
thanks. thats exactly what it was
tj , wrangler , fuel , rail , leak , injector
Fuel Rail/Injector Installation Questions 1995Moneypit YJ Wrangler Technical Forum 2 06-21-2010 06:57 PM
Question about depressurizing fuel system and removing injector rail superslayer TJ Wrangler Technical Forum 23 12-30-2009 12:04 PM
2002 4.0 fuel rail leak HELP jzhawk TJ Wrangler Technical Forum 24 04-09-2009 06:53 PM
Fuel Injector Rail cleaner agony1 YJ Wrangler Technical Forum 0 04-04-2008 09:01 AM
Fuel rail leak jeepraider TJ Wrangler Technical Forum 0 01-14-2008 09:30 AM
