Fuel pump kill switch design/ set up - JeepForum.com
post #1 of 23 Old 03-09-2010, 07:09 PM Thread Starter
dougiefresh131
alright, so I want to make and install a fuel pump kill switch. I know there's many other threads here about doing this, but I could not find what i was looking for. After reading through many threads, most of them say that its more effective to have an ignition kill switch or various other kill switches. I want just a fuel pump kill switch because my alarm system has a kill switch built in. I don't really trust my alarm so this is why I want to install a fuel pump switch. now heres the catch, I KNOW NOTHING ABOUT ELECTRONICS/ WIRES. my dad however, does. but he knows nothing about cars. Few questions. Where can I see a write up of everything I need to buy and everything i need to do including pictures. I've searched this forum and google, and i haven't found anything. Also, I've seen many threads talking about installing a relay. I also saw that relays are useful with high current wires, yet the fuel pump wires (from what I've learned), isn't high current/power or whatever. So can i simply cut one of the power wires, and put a switch in and be done with it? If so, where can I find this wire? Because i don't have a FSM or any type of book.
Thanks so much
dougiefresh131 is offline
post #2 of 23 Old 03-09-2010, 07:47 PM
Neil F.
Here is info for a kill switch. You don't have to get fancy an use a magnetic switch. You can use the info here to know what wire to tap into. I used hard switches. I have two in series have them hidden but easy to activate. Updated – TJ Theft Protection ADE/ADE-II w/Light Chaos - JeepsUnlimited.com Forums
Neil F. is offline
post #3 of 23 Old 03-09-2010, 08:10 PM
gotmudnj
that site makes my eyes hurt thats alot of wiring and write up for one to handle in one sitting lol...
**** Happens.....
~~GOT MUD CENTRAL NEW JERSEY 4x4 ~~
gotmudnj is offline
post #4 of 23 Old 03-09-2010, 09:06 PM
Neil F.
It's very simple. This is all you need. Cut the blue wire and add a switch.
Installing on 2003 - 2004 TJ
If you are installing the ADE System on your 2003 - 2004 model year TJ you will need to find Connector 103. (See location drawing above.)
It is located on the firewall inside the engine compartment. Connector 103 is Black in color and has a total of 14 pins.
You then look for the (Solid) BLUE wire coming from Pin # 9.
Edited the post. I did not realize it pasted multiple times.
Neil F. is offline
post #5 of 23 Old 03-10-2010, 09:49 AM
biffgnar
biffgnar's Avatar
Instead of a magnetic switch or adding a new hidden switch how about wiring this to the factory rear window wiper switch? I sold my hard top so not going to need that. With the factory look to the switch I would think would work well for hiding the switch in plain sight. Would it be a simple as opening the center console and wiring the ADE relay into that rocker switch? Is wiring into the switch simple?
Romney in 2020!
biffgnar is offline
post #6 of 23 Old 03-10-2010, 05:56 PM Thread Starter
dougiefresh131
i would like to know this as well. i was thinking about this but wasn't sure how it would be done.
also, is there a benefit of using a relay over a hard switch?
post #7 of 23 Old 05-10-2010, 11:35 AM
sixspeeds
When you say "and add a switch" what do you exactly mean. How do you go about this. Sorry I'm not very savvy with electrical stuff yet so I need a little more detail in regards to how this switch is put in. Can you offer any further explanation? Thanks!
sixspeeds is offline
post #8 of 23 Old 06-08-2010, 11:16 AM
danielbuck
1946 CJ2
Neil, when you say the blue wire from Pin #9, are you saying that's the power to the fuel pump? Or does that apply only if you are doing the full ADE system?
I too would like to setup a simple fuel pump kill switch (maybe later suplimented with a seperate switch for the clutch kill, but I'll worry about that later), but I'd rather not get into alot of wiring, since I've not had much experience with electrical stuff. I'd just like to cut the fuel pump power (or ground?), run two wires into the tub somewhere and insert a switch.
I was thinking there's probably an easy place somewhere more towards the rear of the vehicle where I could cut the fuel pump wire (rather than under the hood near the computer), and then mount the switch somewhere NOT on the dash, since I imagine most folks would look for a kill switch on the dash.
danielbuck is offline
post #9 of 23 Old 06-08-2010, 11:27 AM
timberwolf0122
Isn't it easier just to pop the hood and whip out the starter relay? What thief is going to spend ages trying to start a car with a dead-starter?
Atheist Jeep Club Member #2
Doctor Who has died 13 times, is on his 14th regeneration and has a time machine, beat that Jesus.
timberwolf0122 is offline
post #10 of 23 Old 06-08-2010, 11:41 AM
biffgnar
biffgnar's Avatar
For occassional instances maybe, but how often do you really want to be doing that? Switch works easily every time. Also, if thief decides he's willing to keep trying a missing relay is pretty obvious and not too hard to jump. With a switch and the circuit interrupt both well hidden seems a lot less obvious and therefore harder to defeat.
Romney in 2020!
biffgnar is offline
post #11 of 23 Old 06-08-2010, 11:48 AM
Neil F.
The Blue wire is for the ADE. The ADE cuts the operation of a number if items preventing the vehicle from starting at all. Cutting that wire vs cutting a fuel pump wire is the same amount of work You can put the switch anywhere in the interior. I actually have two switchec in series. Hitting either switch will do it. If both are set, you would have to get both of them. Both are well hidden but in easy reach.
Neil F. is offline
post #12 of 23 Old 06-08-2010, 11:51 AM
Neil F.
Because you don't want to tip some one off what you did to disable it. If some one who wanted you car happened to observe you, they may more easly find it. Now granted they would have to look under the hood, then go to the parts store or use another relay. If some one in your neighborhood sees you do that regularly, they will figure it out.
Neil F. is offline
post #13 of 23 Old 06-08-2010, 11:57 AM
timberwolf0122
Because you don't want to tip some one off what you did to disable it. If some one who wanted you car happened to observe you, they may more easly find it. Now granted they would have to look under the hood, then go to the parts store or use another relay. If some one in you neighbor hood sees you do that regularly, they will figure it out.
Good point, I only ever bother if I'm leaving her in an airport car park... that said lat time I parked in one I found leaving the lights on a most effective immobilizer.
post #14 of 23 Old 06-08-2010, 12:00 PM
dworjan
I'm working on this too (soon as it gets less than blazingly hot outside), but I'm a bit more electrical wiring savvy, so let me see if I can help.
The ADE system is designed to kill everything that needs the ignition on to function. So like it says, fuel pump, ignition coil, etc. Now all that relay coil, diode, magnetic reed swich and so on that is added to that second diagram is simply to allow you to use a magnet to close the circuit, but not need to keep the magnet there once the circuit is closed.
Now if you want to put in a regular switch, like what I'm doing, all that stuff can be replaced by just the switch. So all you really need for this project is a set of wire cutters/strippers, an on/off switch (make sure you get a 12V DC one rated for 30amps or more), and some extra wire to splice into the existing wire and allowing you to run your switch to wherever you want it. I'd tell you what gauge you need, but I haven't taken the panel off to look. You want the same thickness as what is there. If you expose the wiring that you need to cut, you should be able to go over to Radio Shack and have them get you the right stuff. Get some wire nuts, heat shrink, electrical tape or a soldering set to be able to connect the wires together.
Then all you need to do for your switch once you disconnect the battery, is find the wire (using the ADE writeup) for your year that runs the ADE circuit. Cut it, add some extra wire to both ends of the cut, and then add your switch to the extra wire. As long as all your connections are good, put the switch wherever you want, reconnect the battery, and there you go.
Chris
dworjan is offline
post #15 of 23 Old 06-08-2010, 12:05 PM
danielbuck
1946 CJ2
ahh, I gotcha, Yea I chould just splice in an interrupt switch to that blue wire then? I've got a 2006, wonder if my wiring is the same?
cut , fuel , kill , pump , switch
fuel pump kill switch MPoldschool TJ Wrangler Technical Forum 1 07-31-2009 06:14 AM
Fuel pump kill switch '88YJ YJ Wrangler Technical Forum 19 02-25-2007 05:58 AM
fuel pump kill switch crosscheck17 YJ Wrangler Technical Forum 10 04-15-2006 10:44 PM
Fuel pump wire for kill switch Windsor TJ Wrangler Technical Forum 3 09-22-2005 09:06 PM
Does Anyone use a Fuel Pump Kill Switch? 2004JeepTJ TJ Wrangler Technical Forum 5 06-09-2005 01:11 PM
