Fuel pump issue, works when I bypass the relay - JeepForum.com
post #1 of 10 Old 03-12-2010, 03:19 PM Thread Starter
JeSimmers
JeSimmers's Avatar
Here is the scoop. My TJ will not start unless I jump the relay...this completely rules out the fuel pump. Next up is the auto shutdown relay. The ASD is not the problem, because obviously I have spark, because I drive the Jeep all day if I jump the relay. Not the cam sensor, or the crank sensor either, because once again the Jeep is getting spark and no fuel.
Any ideas at all? Thanks in advance!
Red Jeep Club Member #454
JeSimmers is offline
post #2 of 10 Old 03-12-2010, 03:24 PM
Matt99362
Seems to me it would have to be the relay you are jumping...
Matt99362 is offline
post #3 of 10 Old 03-12-2010, 03:28 PM Thread Starter
JeSimmers
JeSimmers's Avatar
I swapped the relay with known good relays, no change
post #4 of 10 Old 03-12-2010, 03:36 PM
Matt99362
the only other thing it could be would be the wiring. When you are "jumping" the relay what all are you cutting out of the equation? Fuses? Wires? Anything?
post #5 of 10 Old 03-12-2010, 03:43 PM Thread Starter
JeSimmers
JeSimmers's Avatar
I am pulling the relay out completely and jumping the pin supplying power to the relay and fuel pump + pin
post #6 of 10 Old 03-12-2010, 03:44 PM
Matt99362
Hmm, okay. It has to be the relay or where the relay plugs into.
post #7 of 10 Old 03-12-2010, 04:59 PM
BlazinJack
remember, you have 2 + wires going to a relay... the power and the "switch". you need to figure out which one you dont have and back track from there
"No beer and no t.v. make Jack something something..."
Colorado Jeep Club #145!!
Black Jeep Society
BlazinJack is offline
post #8 of 10 Old 03-12-2010, 05:29 PM Thread Starter
JeSimmers
JeSimmers's Avatar
Well I believe the "switch" comes from the pcm, after the pcm gets the signal from the asd. Am I correct with this statement?
post #9 of 10 Old 09-27-2010, 07:01 PM
abbs5
Ever find out the answer?
We have the same problem. The same wire feeds the ASD and the fuel pump relay soooo I think it is the wires at some point. Did you ever find out what yours was?
abbs5 is offline
post #10 of 10 Old 09-27-2010, 08:10 PM
Heliparker
what about the ground for the relay? everyone knows Jeeps are Notorious for ground issues
She is a Work in Progress!!
Heliparker is offline
Bypass manual fuel pump???? Need some opinions.. jeepman709 YJ Wrangler Technical Forum 3 09-28-2009 01:02 AM
Fuel Pump Relay - which is it?... crqflier TJ Wrangler Technical Forum 2 09-06-2009 01:56 PM
Fuel Bypass Regulator vs. Replacement Fuel Pump gsmith795 YJ Wrangler Technical Forum 3 06-27-2009 05:35 PM
Fuel pump relay caferacer YJ Wrangler Technical Forum 3 06-16-2008 05:56 AM
fuel pump?fuel filter?relay? garoughrider YJ Wrangler Technical Forum 2 02-26-2008 05:23 AM
