Fuel pump assembly vs. fuel pump? - JeepForum.com
post #1 of 12 Old 11-09-2008, 10:11 PM Thread Starter
eclipse27
What is the difference? I know the jeep fuel pump/assembly is bad. It wont fire up right away. it takes 2 key turns to fire up. And jerry thought it was the regulator on it. Bottom line would a new fuel pump work? And what all is in the fuel pump assembly? Im on a strict budget and trying to fix it properly among the cheapest route. Thanks all.
4-4.5 inch susp. lift. 1 in performance acs. body lift. 5 in offroad foglights. Brushgaurd. Atoz corner armors.Round 4in taillights.D35/30 combo. upgraded horn.radio.8inbazzoka tube.highlift jack. 1.5in wheel spacers. 33' goodyear wrangler mt's.
eclipse27 is offline
post #2 of 12 Old 11-09-2008, 10:58 PM
KKiowaTJ
Get the whole sending unit and pump. With the whole unit you will get a new pressure regulator. Its alot easier to change out, Plus its all new, And if you have a problem you dont have to dissemble it to figure it out. Sometimes the valve in the regulator/pump lets the fuel drain back to the tank which is the reason for the long starting. In the long run its worth the extra $$ for the whole unit. Good luck
MOPAR!
KKiowaTJ is offline
post #3 of 12 Old 11-09-2008, 11:01 PM Thread Starter
eclipse27
how much do the units run?
post #4 of 12 Old 11-09-2008, 11:29 PM
KKiowaTJ
Around $250 for the whole unit. The pump alone is around $125 or so. Look at ebay, Find it cheap and take it to advance auto or auto zone and have them price match it. Thats what i do with all the parts i buy, Find it dirt cheap, Then go to the local parts places and price match.
MOPAR!
KKiowaTJ is offline
post #5 of 12 Old 11-10-2008, 01:20 AM
photontraveler
Old Dude
photontraveler's Avatar
I replaced mine last year. The full unit is well worth the money, time saved and lack of irritation.
photontraveler is offline
post #6 of 12 Old 11-10-2008, 08:14 AM
LeftoverSalmon
LeftoverSalmon's Avatar
When my pump went I only replaced the pump. Its a bit of a pain to get the filter on and get the pump situated in the assembly but its not too bad. I'd rather save the $ - the whole assembly is kinda expensive.
LeftoverSalmon is offline
post #7 of 12 Old 11-10-2008, 11:15 AM
kloppk
Before you replace anything be sure to do the fuel rail pressure tests.
This will determine what you do need to replace.
From your symptoms it sounds as if it's the antidrainback valve in the pressure regulator/filter.
For giggles try turning your key from the OFF position to the RUN position, wait a few seconds, turn the key back to the OFF position. Now turn the key
from the OFF position to the RUN position, wait a few seconds and then try to start it.
If it starts quicker it would point to the drainback valve.
kloppk is offline
post #8 of 12 Old 11-10-2008, 11:34 AM
jamaicanmecrazy
1994 ZJ
Your telling us you get Advance to price match a buy it now on Ebay?????
My understanding is it must be another retailer and not Etailer.
They also claim in stock but they never have it in stock either and have to order it.
jamaicanmecrazy is offline
post #9 of 12 Old 11-10-2008, 08:54 PM
KKiowaTJ
We buy alot of parts from them, Napa, Orielys, etc that they would rather take the price dig than not sell it at all. All i have to do is print the auction out, take it to them to prove that i can for X price to the door, If they dont want to make money that day, Ill wait a few days and get it for the price i want. I also have the federal/state tax exempt numbers along with a D-license. So if its a dealer only part, I get it at cost. But anybody should be able to take in a paper showing a price to the door, If its lower they should match it, If not wouldn't give them my money. BTW Advance and Auto Zone have Ebay accounts and are "super sellers" so they know they aren't loosing any money.
MOPAR!
KKiowaTJ is offline
post #10 of 12 Old 11-10-2008, 09:44 PM
mdori
If it's just the pressure regulator they can be had fairly cheap. http://cgi.ebay.com/ebaymotors/NEW-F...Q5fAccessories
mdori is offline
post #11 of 12 Old 11-11-2008, 05:58 AM
gmiller0737
Mine needs one too (Anti Drain Back) The best price I found for the whole assembly was at Rockauto,com Like $179 + Shipping for a Airtex brand Autozone wants $229
gmiller0737 is offline
post #12 of 12 Old 11-11-2008, 09:18 AM
jamaicanmecrazy
1994 ZJ
It figures how they vary state to state, we should trade zipcodes and compare.
I'd like to know how some sellers on Ebay can drop ship for less than my dealer cost. My warehouse for fitmaster sell 93-98 Grand Cher headlights $22 each. I found them for less shipped on Ebay. My 2.25" BB $60 shipped on Ebay.
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
Fuel Pump module assembly VinoTJ TJ Wrangler Technical Forum 4 03-14-2008 03:19 PM
Replaced fuel pump assembly... Jim Shanks TJ Wrangler Technical Forum 1 11-09-2004 11:04 AM
Fuel Pump Assembly question Jim Shanks TJ Wrangler Technical Forum 6 11-04-2004 01:26 PM
Fuel pump assembly?? The Fuzz YJ Wrangler Technical Forum 0 07-23-2004 05:52 PM
