fuel pump - JeepForum.com
post #1 of 7 Old 03-01-2010, 06:14 PM Thread Starter
kweb
fuel pump
I need to replace my fuel pump but my repair manual says i need to buy the entire fuel pump module (which is $ 303, just the pump $ 142) it says that the fuel pump cannot be replaced, it says i need to buy the whole module, can someone tell me if I need to do the whole module or if I can just replace the pump.
1999
TJ sport
4.0 liter
6 cylinder engine
Thanks for the help
kweb is offline
post #2 of 7 Old 03-01-2010, 07:51 PM
wushaw
Rockin jeep
wushaw's Avatar
Good question, I think you can find the assy cheaper than that though. I paid 222.00 for mine 6mos ago. The check valve is going in mine so I figured 10 years was a good run for a fuel pump assy.
wushaw is offline
post #3 of 7 Old 03-02-2010, 02:54 AM
Jonny Jeep
Jonny Jeep's Avatar
Have a look at the write up here. DailyDrivenTJ-Fuel Pump Repair It shows in detail how to swap the pump and strainers.
You can get the pump cheaper at RockAuto Auto Parts and it comes with the two strainers. $92 for the cheapest they do and you can get 5% off using the discount code from MarkVIII.org Rockauto discount
There are probably dozens available on ebay too not sure about quality though.
Online factory service manuals and parts lists -
If it doesn't work properly, look for the service manual link at the bottom of the page.
Jonny Jeep is online now
post #4 of 7 Old 03-02-2010, 06:29 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
TheBoogieman is offline
post #5 of 7 Old 03-02-2010, 08:19 AM
LilViper95
LilViper95's Avatar
I just bought a new bosch pump from carquest for my 2003, was the complete assembly even had a tag on it with the mopar part number. Looked identical to the assembly that I removed and only cost me around 180. Dealer wanted well over 300 for the identical part!
04 Ram 2500 5.9L 24v HO Cummins
LilViper95 is offline
post #6 of 7 Old 03-02-2010, 08:46 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
What fuel issues are you having?
How many miles are on your Jeep?
You may just want to replace the entire assembly.
Wheelin98TJ is online now
post #7 of 7 Old 03-02-2010, 02:56 PM Thread Starter
kweb
ok thanks for the help everyone, it takes me a few trys to start up my jeep i put a fuel pressure gauge on the fuel rail and when its running I have 33 psi, i need 44 - 55 psi
kweb is offline
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 10:08 AM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 05:42 PM
inline fuel pump or new tank with pump in it? cubbybear YJ Wrangler Technical Forum 2 12-25-2008 06:13 PM
Fuel pump assembly vs. fuel pump? eclipse27 TJ Wrangler Technical Forum 11 11-11-2008 10:18 AM
Electric Fuel Pump Issue, NOT pump 1995yj1978cj YJ Wrangler Technical Forum 4 05-28-2005 01:12 PM
