Fuel Pump...... - JeepForum.com
post #1 of 6 Old 01-05-2009, 06:54 PM Thread Starter
DesertStorm
Fuel Pump......
My TJ crapped on me Sat. evening. The fuel pump is not making any noise, changed relay, etc. How long does it normally take to change the pump? The pump is 99 bux. A whole new drop in assembly is 600. And disadvantages by going with the pump alone and not the whole new tank assembly? Thanks.
*SOON TO BE LINCOLN LOCKED*
97 TJ/2.5L/Auto./31"MTs/Custom Homefab skids/2.5" exhaust no kitty/3" Homefab CAI with cone filter.
DesertStorm is offline
post #2 of 6 Old 01-05-2009, 07:18 PM
mrcleanstj
I haven't done one in my tj yet but last winter i did one in my 97 tahoe.
Took about half a day. I bought just the pump motor itself. No problems so far. Are you sure the pump is done? I tested mine by banging on the fuel tank darn thing started working. I didn't trust it though. It did make a few short runs though till i found time to do the job.
A person once told me i was driving beyond the capabilities of my vehicle - obviously they never seen the capabilities of a jeep!
This space saved for info:
mrcleanstj is offline
post #3 of 6 Old 01-06-2009, 06:53 AM
jbramble24
You must be talking to the stealership if you are looking at $600 for the pump and assembly. I would probably go ahead and replace the whole assembly if I was going to drop the tank. It's not a real difficult job but not something you want to do on a weekly basis. You should be able to pick up the whole assembly at checker for less than $300.
GM 350 Powered 1984 CJ-7
jbramble24 is offline
post #4 of 6 Old 01-06-2009, 08:08 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
You can get them on ebay for $200 complete.
TheBoogieman is offline
post #5 of 6 Old 01-06-2009, 01:27 PM
Jonny Jeep
Jonny Jeep's Avatar
Write up on dailydriventj.
I've dropped my tank twice now. Once to reshape the stock tank and skid. Last time to replace the two strainers at the bottom and the fuel/filter regulator that had a leaky check valve. Swapping the strainers and regulator unit only took about an hour and a quarter as I pretty much knew what I was doing with the help of Michael_K's write up. Have a good read of the write up and study the pictures, it'll make the job a lot easier. And make sure the tank has as little fuel as possible to lighten the load.
With the help of the write up, you might be able to do it between two-three hours. I found that one of the hardest parts to do was getting the ring of that holds the pump assembly in place.
Jonny Jeep is offline
post #6 of 6 Old 03-27-2009, 09:48 PM
joe130
I have a complete fuel sending unit (200 miles on it) on eBay right now that is currently going for $10. Just go to ebay and search for jeep wrangler fuel sending unit.
The swap is pretty easy, just a little time consuming. Lots of writeups out there for it.
joe130 is offline
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
1998 TJ wrangler - fuel pump sending unit / fuel gauge drummerchukb1 TJ Wrangler Technical Forum 3 05-11-2009 04:42 PM
inline fuel pump or new tank with pump in it? cubbybear YJ Wrangler Technical Forum 2 12-25-2008 05:13 PM
Fuel pump assembly vs. fuel pump? eclipse27 TJ Wrangler Technical Forum 11 11-11-2008 09:18 AM
Electric Fuel Pump Issue, NOT pump 1995yj1978cj YJ Wrangler Technical Forum 4 05-28-2005 12:12 PM
