fuel pressure regulator - JeepForum.com
post #1 of 4 Old 12-18-2010, 11:55 AM Thread Starter
Gubni
When my jeep sits it's hard to start. I checked and it has no fuel pressure. I think maybe the pressure regulator is bad. I think this is part of the fuel pump assembly. Can it be gotten seporately? Any other ideals of the problem?
I searched and found this.
http://www.jeepforum.com/forum/f9/je...arting-257864/
85 CJ7, 350, NP435, Dana 300, 60-14b, 44" boggers
97 TJ 4.0L, auto transmission, stock
Gubni is offline
post #2 of 4 Old 12-18-2010, 03:34 PM
Jonny Jeep
Jonny Jeep's Avatar
You can buy the combined fuel filter/regulator on ebay, and i think rockauto.com do them as well. You can get a 5 percent discount using the code at markvii.com or markviii.com not sure as on phone at mo. Check my other posts, you should find a link.
Jonny Jeep is offline
post #3 of 4 Old 12-18-2010, 03:37 PM
loic
you have to drop the gas tank, the job is easy, I replaced mine a year ago. buy the whole assembly. use jack under the tank, before you lower it down completly, on the top left on the tank, you have electrical conection, disconect them.
I use a motorcycle jack, it was easier.
loic is offline
post #4 of 4 Old 12-18-2010, 05:49 PM
browning
2007 KJ Liberty
fuel pressure will drop to 0 when motor has stopped BUT the fuel line must not drain out ...i changed my fuel pump last week because i had the same problem ..new fuel pump installed and the problem was still there..now we made some tests and found that i had a leak near the front fuel line were they put the rubber shrink on the stainless steel fuel line ...changed the fuel line and end of problem ...pic below is of the fuel regulator which sits on top of the fuel tank ...you also have a check valve inside the fuel pump ...
bone collector
browning is offline
Fuel Pressure Regulator veritas4156 YJ Wrangler Technical Forum 11 03-07-2010 03:26 PM
fuel pressure regulator 2.5l Bryan01702 YJ Wrangler Technical Forum 8 01-26-2010 10:08 PM
95 YJ fuel pressure regulator Sacatone YJ Wrangler Technical Forum 2 03-10-2008 03:04 PM
fuel pressure regulator Sfrid073 TJ Wrangler Technical Forum 2 07-22-2005 09:50 PM
Fuel Pressure Regulator tclark YJ Wrangler Technical Forum 10 04-12-2005 02:16 PM
