fuel line connections - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > fuel line connections
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 12-09-2013, 03:18 PM   #1
SteveJcoYJ
The rubber supply line the goes from the pump to the hard line that goes into the fuel filter. I'm just using a metal band clamp to secure the rubber line. It's leaking on me. The rubber line is new and the line is stainless, I'm thinking there should be a better way. What have you guys got?
SteveJcoYJ is offline   Reply With Quote
Unread 12-09-2013, 03:45 PM   #2
JBTJ
JEEPer For Life
JBTJ's Avatar
Use a better clamp.
JBTJ is offline   Reply With Quote
Unread 12-09-2013, 05:40 PM   #3
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
STEVEJCOYJ'S JEEP
Year & Model
A TJ...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote
