Fuel Injectors - JeepForum.com
post #1 of 5 Old 01-24-2008, 05:42 PM Thread Starter
Hot Sauce
Fuel Injectors
Does anyone know the lbs./hr. rating of stock 2.5L fuel injectors?
Hot Sauce is offline
post #2 of 5 Old 01-24-2008, 06:21 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
No but if you're thinking of installing higher flow injectors, don't bother. The ECM (engine computer) will cut the FI pulse duration length so the same amount of fuel will get into the combustion chambers no matter how much the injectors are capable of. The ECM wants a specific air-fuel ratio and it'll do whatever it takes to achieve it.
Getting
Jerry Bransford is online now
post #3 of 5 Old 01-24-2008, 09:56 PM Thread Starter
Hot Sauce
Actually I wasn't looking to upgrade, just wanted to know. That's good info though. Thanks
post #4 of 5 Old 08-07-2010, 04:43 PM
Jeeper_YJ
Question Jerry? Why are the guys reporting more power? I have also seen dyno's with 99+ intake and injectors that show more power too? Confused.
'97 Cherokee, 99+ intake, 62mm TB, 703 injectors (new), k&n intake, Hypertech III, 180* stat (1/8" drilled hole), 2.5" manifold 2 tail pipe (Hooker Maxflow & hi flow cat), Perf header, 4.5" zone lift, 32" GY Dura Trac, Rear head rests. Comp cam "231" & Perf head (LS1 BIG valves 2.02/1.62). 3 row alum radiator.
Jeeper_YJ is offline
post #5 of 5 Old 08-07-2010, 05:01 PM
Jerry Bransford
Administrator
Test results are mixed on the old vs. new style air intake manifold. And seat-of-the-pants reports on any performance mod are usually highly affected by the placebo effect. Some dyno tests say the different shaped manifold helps, other dynos say it doesn't. I personally don't feel any difference between the power produced by my '04 with the newer rounded manifold vs. my '97 that had the older squared off intake manifold.
And so far as the injectors go, a stock engine isn't going to respond to a different injector with more flow capacity for one reason.... because the computer adjusts the pulse width (spray duration) going to the injector to assure it only sprays exactly only the amount of fuel the computer requires to achieve the required air-fuel ratio. If the injector has more flow capacity, the computer will shorten the pulse width duration so it doesn't spray for as long. That is how the computer is able to keep the air-fuel mixture right where it wants it. The only way to get it to start spraying more fuel is to force more air into the air intake and the only way you'll do that is with something like a supercharger or turbocharger.
Getting
TJ 2.5l fuel injectors choeyreplied TJ Wrangler Technical Forum 5 12-15-2009 11:56 AM
H.O. vs Non-H.O. Fuel Injectors JohnFM3 YJ Wrangler Technical Forum 1 11-06-2009 11:28 AM
Are TJ fuel injectors any better than YJ injectors? Drdan524 YJ Wrangler Technical Forum 10 04-01-2009 03:52 PM
fuel injectors LeftoverSalmon TJ Wrangler Technical Forum 1 02-13-2008 09:21 AM
Exhaust Manifold Help : Lost on how to remove Fuel injectors, wiring, and fuel rail. Mr. Notorious YJ Wrangler Technical Forum 9 08-10-2005 07:00 PM
