Fuel Injector cuts out with downhill or hard braking - JeepForum.com
post #1 of 4 Old 08-16-2017, 10:14 PM Thread Starter
MDTJ
MDTJ's Avatar
I just got back from a trip to Colorado to run some trails. On the trip I discovered my number 4 fuel injector (according to the code: P0204) is lazy. On a steep downhill it quits working. Same thing if I brake hard on the street.
Any thoughts on what causes that?
Good resources:
MDTJ is offline
post #2 of 4 Old 08-16-2017, 10:29 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Swap it with a different fuel injector and note if the problem follows the fuel injector or stays at the same #4 location.
Jerry Bransford is offline
post #3 of 4 Old 08-17-2017, 04:02 PM Thread Starter
MDTJ
MDTJ's Avatar
Will do. I was hoping this might be a known issue (even though search didn't find any results).
Not long ago I tested all the injectors manually and used the test light on the wiring. The challenge is the injector works fine most of the time. Which makes it extra hard to diagnose.
Good resources:
MDTJ is offline
post #4 of 4 Old 08-18-2017, 02:23 AM
Jonny Jeep
Jonny Jeep's Avatar
Going down a steep hill or during braking the PCM can switch to deceleration mode which cuts fuel. This is normal. As suggested start by swapping the injector to another cylinder.
Sent from my D5803 using JeepForum
Jonny Jeep is offline
