Fuel filter, air filter, dirty injectors??? - Page 2 - JeepForum.com
post #16 of 28 Old 01-09-2013, 09:09 PM Thread Starter
RedJeepWhiteTop
OMG, i didn't think the on off on off on trick would work after trying it a few times, then i tried it real fast and sure enough it worked, it gave me a check engine light 12!
Now i just have to research what that means.
Thanks everyone!
RedJeepWhiteTop is offline
post #17 of 28 Old 01-09-2013, 09:15 PM Thread Starter
RedJeepWhiteTop
So it says that a code 12 is just letting me know that the battery has been disconnected within the last 50 cycles...which i did to do the tune up and ignition coil installs
I guess I will check out the TPS when there is some daylight.
post #18 of 28 Old 01-10-2013, 12:17 AM
mukluk
The TPS was what I was thinking of as well; sometimes the problem can be caused by carbon fouling in the sensor, you can try quickly running the TPS through its range of motion multiple times to see if that helps any (pump the hell out of the accelerator pedal a bunch of times, then start it up and take it for a drive - see if things are improved).
mukluk is offline
post #19 of 28 Old 01-10-2013, 06:16 PM
JPNinPA
If it isn't not the TPS I'd verify the restricted intake or exhaust. Clogged CAT, rotting pipes, any debris in the exhaust will do it.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #20 of 28 Old 01-12-2013, 05:13 PM Thread Starter
RedJeepWhiteTop
Well I went ahead and replaced the TPS and there was a big improvement! But, the misfire is still there just faintly. Im going to let my wife drive it around for the next week and see how it goes. Thanks everyone!
post #21 of 28 Old 01-12-2013, 06:51 PM
JPNinPA
If its a true misfire you will throw a code. Is it a low pum, pum, pum noise at idle?
What kind of plugs did you use? Gap and tighten them correctly?
JPNinPA is offline
post #22 of 28 Old 01-13-2013, 09:39 AM Thread Starter
RedJeepWhiteTop
At idle it runs super smooth, it just when you get going the engine hesitates a little. I just used the plugs that it calls for underneath the hood.
post #23 of 28 Old 01-20-2013, 10:24 PM Thread Starter
RedJeepWhiteTop
Well the problem has come back again, still the same symptoms i guess ill check the exhaust?
post #24 of 28 Old 01-21-2013, 07:03 AM
JPNinPA
Where did you buy the TPS from? Sometimes they are bad or go bad quickly right out of the box.
JPNinPA is offline
post #25 of 28 Old 07-21-2015, 11:22 AM
hawkdriver1108
I am having the same problem. What did you figure out to be the problem? ?
hawkdriver1108 is offline
post #26 of 28 Old 07-21-2015, 11:23 AM
hawkdriver1108
What did you figure out to be the problem. I'm having the same issue.
post #27 of 28 Old 07-21-2015, 11:26 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
This thread is 2.5 years old and RedJeepWhiteTop hasn't been here since. I doubt he's going to answer you.
Getting
Jerry Bransford is online now
post #28 of 28 Old 07-21-2015, 04:29 PM
hawkdriver1108
Ok..thanks man
1997 , engine , filter , tj
Replace fuel filter, air filter then hesistation 4.2 befumo YJ Wrangler Technical Forum 4 05-01-2012 05:04 PM
air filter getting dirty quick bigtim6656 TJ Wrangler Technical Forum 14 09-21-2011 11:23 PM
Fuel injectors and filter superman_jjs YJ Wrangler Technical Forum 4 04-25-2011 11:12 AM
2.5L acts like dirty fuel filter help please balzer TJ Wrangler Technical Forum 10 05-30-2010 10:29 AM
A very dirty cylindrical air filter. What's it for? Jay Lu TJ Wrangler Technical Forum 5 11-07-2003 01:44 PM
