#1 | |
fuel cell
Just trying to get some info on them. I would like to put one in but dont know a ton about them.
Just looking for any info and what I would need other then the actual fuel cell itself
2002 Dodge Dakota quad cab V8 2011 Dodge Grand Caravan |
#2 |
Just for clarity, do you mean the alternative fuel device for use with hydrogen, or a large gas tank?
Steve Minister of Propaganda |
#3 |
#4 |
For a TJ, most people go with the setup that I run.
Get this fuel cell: http://store.summitracing.com/partdetail.asp?autofilter=1&part=RCI%2D2161A&N=700 +115&autoview=sku Then cut a hole in the top of the fuel cell and buy this ring kit: http://www.kore4x4customs.com/asccustompages/products.asp?fpage=1&categoryID=15&productID=4&car tID=384547451 It allows you to use your stock sending unit and comes with a gasket for the cell. Then you just exented your fuel lines using some 5/16" FUEL INJECTION line and extend the wires for the power to the pump. Use one of the bungs on top of the cell to attach to your stock charcoal canister or just run a tube up high on your roll bar and you are done. Here is what it looks like installed before I ran my breather line to the charcoal canister and before I mounted to the jeep: ![]()
1999 Jeep TJ on 1 tons (OLDER) 2003 Jeep Rubicon (OLD) 2008 Jeep Unlimited X (NEW) |
#5 |
Any major issues with running one on a dd (other then gassing up from inside the jeep) such as gauges, causing codes to pop up, etc
#6 | |
#7 |
Just one more sound in the jeep. Probably going to do this to help my departure angle (skids getting pretty dented) and I would like to strech it in the future anyway.
#8 |
Any other input?
#9 |
I might be wrong, I'm sure I'll be corrected quickly, a fuel cell has a type of foam in it that will break down over time, possibly clogging the filter. Also, it won't pass many state inspections.
Stockish 04 Rubicon, slowly but surely sneakin stuff by the wife to make my Jeep unique. I'm with the other guy - want a challenge? Wheel stock. |
#10 | |
Some Call me RockDog
I don't think all of them have the foam. I have heard the ones with foam will deteriorate over time, but I guess a fuel filter would help eliminate problems.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#11 |
good to know, and not too worried about inspections. We only have to get them when ownership changes (unless I get pulled over and get some flack about it). But its going to be hard to notice even if I do get pulled over. That and its eventually going to be trailered
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
