Front XJ shaft for Rear TJ - What years? - JeepForum.com
post #1 of 8 Old 12-06-2007, 03:24 PM Thread Starter
Dogman
Dogman's Avatar
Ok, I've search and googled and I haven't found any answers...
I'm going to have an XJ front shaft cut and balanced to use in in the rear of my TJ. I need to know what years? I'm assuming something like a '96 would work, but I want to be 100% sure I'm getting the right shaft. Also, I've heard of people using front explorer shafts, if that would work, or be cheaper, what years?
TIA
John 3:17
Dogman is offline
post #2 of 8 Old 12-06-2007, 06:28 PM Thread Starter
Dogman
Dogman's Avatar
Bump...anyone?
John 3:17
Dogman is offline
post #3 of 8 Old 12-06-2007, 08:44 PM
flatlander757
Bump out of curiosity's sake... How strong would a front driveshaft used for the rear really be though? I dunno if an XJ front shaft is larger or not, but the front shaft on my TJ is way skinny compared to the rear shaft.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #4 of 8 Old 12-06-2007, 09:11 PM
orangetj05
orangetj05's Avatar
it will work, but you'll have to have it shortened about 2 feet first
2005 TJ 5.7 HEMI, Caged, Locked, Long armed, Stretched, Air shocked, Cromoed, Running 37 Irocks
orangetj05 is offline
post #5 of 8 Old 12-07-2007, 09:53 AM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
Not sure on the year but you will need a flange adapter - Spicer #211229x
I'll see what I can come up with for years...
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #6 of 8 Old 12-07-2007, 10:18 AM
mdm
Farm Wheeler
Originally Posted by dogman
...I'm going to have an XJ front shaft cut and balanced to use in in the rear of my TJ...
I'm assuming you are doing this to avoid the cost of a new rear shaft. Talk with the shop that is going to do the work for you. If you are dealing with a local drive shaft shop the difference in price between modifing an existing drive shaft and building a new one might not be as great as you think esp. when you consider the fact that the new shaft will be built with all new parts.
mdm is offline
post #7 of 8 Old 12-07-2007, 10:53 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I think JP mag did something like this a while back and they said it was just a tad bit more money to have a new heavy duty shaft built for the same price.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #8 of 8 Old 12-07-2007, 11:01 AM
ChiliPalmer
The Cherokee stock specs in the XJ forum list the same specs for the '87's to '01's so I'm assuming they're all the same and I've been looking around and in all the pics I can find it looks like they're the same; if this is the case you can have the one in my garage because I won't need it (the doubler will require me to get a longer front shaft)...
Maybe someone will chime in with more info - it's an '88 by the way.
Forum!
Non-Rubicon driveshaft U-joints. Front shaft and rear shaft use the same? BWFBezerk TJ Wrangler Technical Forum 8 01-15-2010 06:23 AM
XJ front shaft for TJ rear shaft. Couple ?'s TJ311 TJ Wrangler Technical Forum 5 12-09-2009 03:48 PM
xj front drive shaft for yj rear teejmcd YJ Wrangler Technical Forum 1 01-26-2009 04:30 PM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 03:33 PM
Front Drive Shaft For The Rear 86comanche TJ Wrangler Technical Forum 1 07-06-2005 10:43 AM
