front wheel bearing replacement help - JeepForum.com
post #1 of 4 Old 01-21-2008, 06:17 PM Thread Starter
sjfay
does anybody know what size nut is on front to remove hub and wheel bearing i got to replace and is there any thing i should know
sjfay is offline
post #2 of 4 Old 01-21-2008, 06:22 PM
otisdog
2008 WK
Nut is 36 mm. The bearing is a sealed unit called a unit bearing.
http://www.stu-offroad.com/axle/d30/axle-1.htm
There's two different sizes - split was in 2000 I think. If you get the wrong one your brakes will not work right.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #3 of 4 Old 01-21-2008, 06:40 PM Thread Starter
sjfay
thanks very much this site you posted on wheel bearing is perfect thanks again also thanks for your reply on size of the nut
sjfay is offline
post #4 of 4 Old 01-21-2008, 08:35 PM
Stu Olson
Stu Olson's Avatar
You are quite welcome.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
Wheel bearing replacement. BriansCJ TJ Wrangler Technical Forum 4 07-28-2009 03:57 PM
wheel bearing replacement 88wagon TJ Wrangler Technical Forum 9 07-03-2009 06:17 PM
2006 Rubicon Front wheel bearing replacement camhar25 TJ Wrangler Technical Forum 6 08-08-2008 04:57 PM
Front Hub Assembly/wheel bearing replacement Pitr YJ Wrangler Technical Forum 11 12-09-2006 03:54 PM
Wheel bearing replacement mde YJ Wrangler Technical Forum 2 09-16-2003 07:55 PM
