Front wheel bearing? - JeepForum.com
post #1 of 2 Old 04-24-2006, 06:23 PM Thread Starter
Tj4rocks
I had the front wheel off tonight to check the fitment of my new wheels and i noticed some play in the front end. If i grab the tire from the top and bottom, i can wiggle it quite a bit. Just like the wheel bearings need to be tightened up. From what i have been told, you can't tighten the bearings on a tj. Does this sound like i need to replace the front hub? It's not ball joints, when i move the wheel i can see the outer axle shaft move slightly in the knuckle. I would just like to have a idea before i start tearing into things. Thanks.
97 TJ Sport 5 speed
4 inch teraflex
33x12.50 trxus
Tj4rocks is offline
post #2 of 2 Old 04-24-2006, 06:44 PM
Dukes69
Dukes69's Avatar
they are called "unit bearings" and are a sealed, non-serviceable, part. IIRC they cost around $100.
AIM: Dukes69
Ya Savvy?
Dukes69 is offline
front wheel bearing cpundsack YJ Wrangler Technical Forum 19 12-24-2009 08:28 AM
right front wheel bearing gone steve62 TJ Wrangler Technical Forum 3 03-08-2009 01:55 PM
Front wheel bearing help. MoJeeper TJ Wrangler Technical Forum 4 07-02-2008 01:31 AM
Front Wheel Bearing help vmkwrangler YJ Wrangler Technical Forum 14 02-06-2005 06:17 AM
Front Wheel Bearing Resqfiremedic YJ Wrangler Technical Forum 4 12-23-2002 12:25 PM
