Front Unit Bearing - Does it NEED the Driveshaft Bolted In? - JeepForum.com
post #1 of 9 Old 08-20-2007, 05:15 PM Thread Starter
lupinsea
lupinsea's Avatar
Can you run on JUST a front unit bearing / hub without the TJ's front axleshafts if need be?
This weekend we discovered (on the trail) that a friend of mine had a busted front axleshaft (right at the unit bearing) AND a toasted unit bearing. There wasn't much we could do about the axle but pull it but figured we could replace the front unit bearing so that he could at least get home.
Afte a getting a new unit bearing from the parts store we installed it (without any driveshaft at all) and proceeded to drive our Jeeps into town. We got about 20 miles into town when the wheel fell off when starting up at an intersection. The new unit bearing had just completely separated and come apart. When the wheel went it ripped of the caliper and shattered the front steering knuckle caliper mounts. Fortunately my friend was only going about 2-3 mph when it happened but it raised the question:
Does the TJ's front unit bearing NEED the sub-shaft of the front axle shaft to be inserted into the bearing and the axle nut torqued down to keep the bearing from separating?
Any thoughts on why the repalcement unit bearing separated?
- Jay
lupinsea is offline
post #2 of 9 Old 08-20-2007, 05:34 PM
andy02
This thread talks about that on starting on the second page I think
http://www.jeepforum.com/forum/f9/can-i-drive-without-my-inner-front-axle-shaft-451806/
Originally Posted by Hendrix
September 11 2001
Never Forget!
andy02 is offline
post #3 of 9 Old 08-20-2007, 05:40 PM
Bigbob
Bigbob's Avatar
You have to have the stub in there or the bearing will come apart.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #4 of 9 Old 08-20-2007, 06:18 PM
McLovin
dopn't ever ever run without the stub shaft in there. Some poor guy did that and died just recently.....
McLovin is offline
post #5 of 9 Old 08-20-2007, 07:04 PM
CCrew
Yes, the stub axle needs to be installed. It separated because it wasn't. If you ever get in that situation again, you have to leave the stub installed, and you can pull the inner axle and stuff a rag in the housing to get you home.
-Roger
CCrew is offline
post #6 of 9 Old 08-21-2007, 10:27 AM
kizer
kizer's Avatar
I be the victim he's talking about. Lessoned learned.
http://www.links4jeeps.com/phpBB2/viewtopic.php?t=6279
Problem was there wasn't a shaft left for the backside of the bearing to hold against.
1600+ Write-ups, and more
kizer is offline
post #7 of 9 Old 08-21-2007, 01:31 PM
Kerndone
I lack money
Kerndone's Avatar
The unit bearing is not held together by anything but the axle nut that bolts to the stub shaft. Think of it like two halves, the inner half bolts to the knuckle while the outer half bolts to the wheel. Without the stub shaft bolted in place with the axle nut, holding the two halves together, it WILL (there is no IF here) come apart.
I keep a 36mm socket, and spare front shafts in my TJ at all times.
Red Jeep Club Member 111
'99 TJ - work in progress...see profile
'08 WK - Silver RME, DD.
Kerndone is offline
post #8 of 9 Old 08-21-2007, 01:35 PM
PeteC
Originally Posted by lupinsea.......................................... ..................................................
Does the TJ's front unit bearing [I
NEED[/I] the sub-shaft of the front axle shaft to be inserted into the bearing and the axle nut torqued down to keep the bearing from separating?
Simple answer......YES
But only if you want to avoid the very thing that already happened.
The hub will fail without the outer shaft and nut installed.
'00 TJ With toys, lift and tires.
'10 Dodge Ram 1500 Quad 4x4. Daily driver and tow rig
'05 Dodge Neon. Wifes daily driver and gas sipper.
There is no Bandaid for Stupidity
Sorry if my support of legal wheeling offends you
PeteC is offline
post #9 of 9 Old 08-21-2007, 01:37 PM
rljsrubicon
Not good
It's not a good thing; in fact very bad... Ron
rljsrubicon is offline
What else do i need? Unit Bearing job ChrisYJ - Italy YJ Wrangler Technical Forum 5 08-25-2009 05:23 AM
94 YJ-is the front fender bolted on or wildbadbill YJ Wrangler Technical Forum 4 04-13-2009 10:17 AM
Front unit bearing Swap Q's lukera TJ Wrangler Technical Forum 4 06-03-2008 09:28 PM
D30 unit bearing grenMEG YJ Wrangler Technical Forum 5 03-05-2008 02:18 PM
Bolted on my Jeeperman Front Bumper limerock TJ Wrangler Technical Forum 5 03-14-2007 09:54 PM
