Front trackbar relocation by drill and rear trackbar relocation bracket install? - JeepForum.com
post #1 of 21 Old 03-28-2006, 01:38 PM Thread Starter
loudog3114
Im just wondering if this stuff is pretty easy or not? I decided to go the cheap route and re-drill my front track bar mounting bracket 3/4" over and add a relocation bracket in back.
92 YJ, 35's, 6", Locked
97 Honda CBR1100xx
08 336XI
loudog3114 is offline
post #2 of 21 Old 03-28-2006, 01:43 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That's what I did years ago before I was able to install adjustable length trackbars from Rubicon Express. Just be careful when drilling that front trackbar mounting hole, you don't want to get the hole too close to the edge and weaken the mounting bracket. Mine held up fine to some pretty tough trails.
Jerry Bransford is online now
post #3 of 21 Old 03-28-2006, 02:05 PM
EaglesSJ
EaglesSJ's Avatar
I never redrilled my front one and I cant even tell. I will be getting a new front trackbar soon anyways.
EaglesSJ is offline
post #4 of 21 Old 03-29-2006, 08:27 AM
jeep3908
I just did it this week end and it was real easy. On the front I used a square and measured over 3/4" to the right and drilled. The back, I mounted the bracket in the existing holes then drilled the new hole using the bracket as a guide to make sure I got it in the right place. You will see what im talking about when you start to do it.
jeep3908 is offline
post #5 of 21 Old 03-29-2006, 08:34 AM
BlackOpsJeep
anyone have a picture of what and where you drilled on the front.
Thanks
2006 Silver X 2" BDS lift, 1" PA BL, JKS BMML, BFG 33x10.50x15
BlackOpsJeep is offline
post #6 of 21 Old 03-29-2006, 08:41 AM
RockRunner85
Heres a pic I had from awhile ago. I have since then bent back the bracket and went with an adjustable track bar. Much better as it tightened up the front end.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #7 of 21 Old 03-29-2006, 10:34 AM
ClemsonJeepGC
how do you know how far over to move the hole? Is there a standard amount to go over based on lift height? Or do you just measure? For example, if my tire sticks out an 1" further on driver side would I then move the hole .5" over?
And what kind and size of drill bit do you use?
1998 Green Sahara - Rusty's 3", 33x12.50 BFG AT, RE Track Bar, Gambler wheels, 1.25" spacers, home made window roll, rear olympic rockslider bumper, Kenwood KSC-SW1 Sub
2004 Black Tacoma TRD
ClemsonJeepGC is offline
post #8 of 21 Old 06-01-2009, 08:22 AM
wingshooter2009
bump for the above question
./l ,[___],
l---L – ()lllllll()-
()_) ()_)--o-)_)
Black Jeep Society member
Eagle Scout Jeeper #1
Mecklenburg Mudders Vice President
wingshooter2009 is offline
post #9 of 21 Old 06-01-2009, 08:25 AM
2000jeeper
I am using the RE adjustable track bar both front and rear. RE says to drill front hole to 5/8 inch. This was very easy if you have a sharp drill bit. The rear i used there bracket part number 1602 for there rear adjustable bar. again very easy to install.
2000jeeper is offline
post #10 of 21 Old 06-01-2009, 06:29 PM
jrtdogbone
jrtdogbone's Avatar
http://www.jeep-willys.com/tjparts.htm
Rear
The Dog
2004 Jeep Willys
jrtdogbone is offline
post #11 of 21 Old 06-01-2009, 07:23 PM
NE4X4
I have installed two RE superfles lifts and both have left the rear axle off toward the passenger side, one was 3/4" and the other was 1/2". Both times we installed the track bar bracket. I was wondering if this is a common problem? Don't mean to hijack the thread, but this could be important. Make sure to check your tracking when you finish with a lift install.
NE4X4 is offline
post #12 of 21 Old 06-01-2009, 11:09 PM
mudb8
want it rite or rite now?
mudb8's Avatar
that's correct..... drill the same size as the stock hole..
as jerry mentioned, you don't want to drill to close to the existing hole..
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #13 of 21 Old 11-16-2009, 06:58 PM
lamberga
NE4X4
Just finished my RE 4.5" superflex on my TJ. Haven't measured the rear yet, but it is definitely off at least 1/2". I think this problem must be common. I really would love to be done and enjoy the kit as I would like to buy tires, but I think my first obligation is to get the rear end lined up. Does anybody have a solution other than spending another $165 bones on the adjustable track bar? Please advise. Thanks.
lamberga is offline
post #14 of 21 Old 01-27-2010, 05:17 PM
PurpleZJ
for the rear you can get a rear track bar relocation bracket. i picked one up from RUK industries for my ZJ for about 30 bucks. and you can get one for the front as well. but for the front you can just drill a new hole as a temporary solution as well. i'm considering getting one for the front of my ZJ instead of drilling a hole but havent decided yet
1996 ZJ- 4.0, AX-15 5SPD/NP242, RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
RIP Troy (bigbluezj94) you wont be forgotten
December 2010 GCOTM
5spd ZJ Club Member 001
Glad you are ok. If you were a cat, you would be down to 8.:D
Originally Posted by Greengc4x4 View Post
Everything looks great, Hellen Keller! :D
Originally Posted by rritch View Post
plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:
RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11
PurpleZJ is offline
post #15 of 21 Old 07-04-2010, 09:38 AM
morningpride
I did the rear bracket on my RC 3.25 Worked well!
morningpride is offline
Front Trackbar Relocation Bracket Jeep1067 TJ Wrangler Technical Forum 19 01-28-2010 05:32 AM
98 TJ rear trackbar relocation bracket install question kremerguy TJ Wrangler Technical Forum 4 10-04-2009 09:22 AM
Will I need a trackbar relocation bracket with rear adjustable trackbar FLATFENDER54 TJ Wrangler Technical Forum 3 02-05-2009 03:35 PM
Rear Trackbar Relocation Bracket chrisgardner73 JK Wrangler Technical Forum 2 01-09-2008 04:22 AM
JKS trackbar relocation bracket (front) BNovak TJ Wrangler Technical Forum 0 11-16-2006 05:55 PM
