Front track bar & drop pitman arm - JeepForum.com
post #1 of 8 Old 12-22-2010, 06:26 PM Thread Starter
m361
I've been struggling to find the source of my steering slop for quite some time. With the help of this forum, I think I have narrowed it down to the track bar. I definitely have some movement where the track bar attaches to the frame when the wheel is turned. I am assuming I can not just replace that bushing, so I guess I am in the market for a replacement track bar. I'm thinking I might as well get an adjustable track bar, but I need to find one that is affordable yet is decent quality. I'm not a hard core wheeler, but I do get it off the pavement from time to time. Any suggestions on brand?
Also, I have a drop pitman arm. I've read in some forums that it is not really necessary, and may also cause some steering slop. Should I try to find a stock pitman arm and replace it?
m361 is offline
post #2 of 8 Old 12-22-2010, 07:16 PM Thread Starter
m361
Bump.
m361 is offline
post #3 of 8 Old 12-22-2010, 07:19 PM
cheapjeep06
Unless you have an aftermarket track bar with a drop bracket at the frame, you do not need a DPA. This will cause bumpsteer. I don't have much experience with aftermarket track bars except for the Rough Country one that I have. It does not require a DPA, has a beefy bracket on the frame, uses a poly bushing at frame end, and a heim joint on the axle end. Only concerns are the tb is hollow, and the heim doesn't seem that beefy. Other than that, I haven't had a problem with it.
Rustys blows big, fat camel nuts.
cheapjeep06 is offline
post #4 of 8 Old 12-22-2010, 07:23 PM
rondak46
JKS, and you will not have problems in the future with diff cover clearance.
rondak46 is offline
post #5 of 8 Old 12-22-2010, 07:30 PM Thread Starter
m361
Hey...thanks cheapjeep06 and Rondak46. I'll look into both of those track bars.
m361 is offline
post #6 of 8 Old 12-23-2010, 02:38 PM Thread Starter
m361
Update:
I decided to go with a Pro Comp adjustable track bar, only because my local 4 Wheel Parts store had it in stock and I am not patient enough to order online and wait for delivery. Definitely have much improved steering and very little steering slop, but it still drifts a bit on the road. Can't decide if I should remove the drop pitman arm or just take it in for an alignment...or both. Any thoughts on the matter?
m361 is offline
post #7 of 8 Old 12-23-2010, 03:55 PM
conrasm
conrasm's Avatar
If the pitman is lower than where the track bar attaches to the frame, then take it off and put a stock one on. Ypu will end up with bump steer with axle articulation if the track bar and drag link are not parallel. You only need a drop pitman arm if you have a track bar lowering bracket. 4wd.com has stock pitman arms for about $18.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #8 of 8 Old 12-23-2010, 04:44 PM Thread Starter
m361
Excellent advise, thank you. I will stop by there tomorrow and get one.
m361 is offline
Poly Perf track bar kit and drag link (drop pitman or flip kit and your results??) premo JK Wrangler Technical Forum 30 03-17-2014 11:47 AM
Front adjustable track bar w/ drop bracket requires DPA? Why? Night Wolf TJ Wrangler Technical Forum 10 12-18-2010 09:48 PM
Front track bar drop bracket.. any good? tooofast TJ Wrangler Technical Forum 13 01-30-2009 09:29 AM
looking for drop pitman arm with more drop than typical 4" DPA swa240z YJ Wrangler Technical Forum 3 04-18-2008 12:35 PM
Need Help with Front track bar and Pitman arm JT29 YJ Wrangler Technical Forum 1 02-26-2005 05:18 AM
