Front track bar - JeepForum.com
post #1 of 3 Old 08-07-2010, 08:49 AM Thread Starter
80 CHOPPER
Front track bar
We talk on here about the importance of properly torquing the track bar bolts and making sure the hole is true and its all attached to a rubber bushing at the axle. Would a heim joint at this location make better sense? I don't have DW but I do get a good shake between 35 an 40.
DRAGON
80 CHOPPER is offline
post #2 of 3 Old 08-07-2010, 09:13 AM
robncar
robncar's Avatar
I'd start with tire balance for a shake within a certain MPH range. Or, swap rear to front and see if anything changes.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 3 Old 08-07-2010, 09:14 AM
DstroyrOfWrldz
if the rubber is in good condition and the opposite end (the rod end) is tight it shouldn't be contributing to a shake.
Even most aftermarket track bars keep a flexible bushing at that location, though I have seen less-flexible polyurethane instead of rubber.
I think a heim joint would transmit a lot of noise into the frame.
If it's only happening between 35 and 40 it sounds more like a tire balance issue.
Joe
1999 Wrangler Sahara
2005 Wrangler Unlimited (Sold 9/2012)
DstroyrOfWrldz is offline
help with front track bar masterofyard TJ Wrangler Technical Forum 6 05-23-2010 07:21 AM
Need help front end messed up: Adjustable front track bar TOLjeep TJ Wrangler Technical Forum 15 12-24-2008 12:32 PM
Front Track Bar & Rear Track Bar Bracket mossimo19 TJ Wrangler Technical Forum 4 09-14-2005 07:56 PM
Keep Front Track Bar? cjb7804 YJ Wrangler Technical Forum 20 04-08-2005 12:38 PM
Front track bar 00greentj TJ Wrangler Technical Forum 4 10-04-2002 09:36 PM
