Front toe in opinions - JeepForum.com
 12Likes
  • 2 Post By biffgnar
  • 1 Post By TJnBC
  • 2 Post By TheBoogieman
  • 1 Post By Shark_13
  • 1 Post By zipman35
  • 1 Post By rbaucom7266
  • 2 Post By Loukaps
post #1 of 12 Old 09-18-2017, 11:16 AM Thread Starter
rbaucom7266
I installed my new track bar and of course it threw my toe in and steering wheel out of wack.
By looking at the pics should I break down the steering and straighten the wheels, put it back together and then set the toe. Or does it look minor enough that I can just adjust the tie rod to set the toe in????
Sent from my iPhone using Tapatalk
rbaucom7266 is online now
post #2 of 12 Old 09-18-2017, 11:25 AM
biffgnar
biffgnar's Avatar
Why would you take anything apart? Set the toe buy adjusting the tie rod. Straighten the steering wheel by adjusting the drag link.
olysteve and rbaucom7266 like this.
biffgnar is offline
post #3 of 12 Old 09-18-2017, 11:37 AM Thread Starter
rbaucom7266
Ok cool, I was thinking that it might be too far out and I would use up all my adjustment to get it back how it's suppose to be. I wasn't sure. I have never had to make that big of an adjustment.
post #4 of 12 Old 09-18-2017, 11:41 AM
biffgnar
biffgnar's Avatar
With an OEM width axle, if you centered it under the jeep when installing the trackbar there should be plenty of adjustment.
biffgnar is offline
post #5 of 12 Old 09-18-2017, 11:46 AM Thread Starter
rbaucom7266
Cool, it's centered money, so I will try it out.
Thanks
post #6 of 12 Old 09-18-2017, 11:49 AM
TJnBC
what biff said.
Just adjust the Toe In. Should be fine , don't take anything apart.
The only time I would take that apart is if the Alignment shop took the draglink off of the Pitman, and didn't align the Pitman correctly (parallel with frame and inline with steering shaft) when they reattached Drag link. Which would could cause less turns one way on the Steering wheel. You would then have to center that Pitman arm and reattach.
rbaucom7266 likes this.
2006 LJR...the madness begins again
TJnBC is offline
post #7 of 12 Old 09-18-2017, 11:49 AM Thread Starter
rbaucom7266
Cool, it's centered, so I will try it out.
Thanks
post #8 of 12 Old 09-18-2017, 12:09 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
So much hostility here. I feel like I'm married again.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #9 of 12 Old 09-18-2017, 01:49 PM
Shark_13
Take a tape measure and see where the toe in is at, then set it where it needs to be.
There is no way you can look at a picture and determine if it's set correctly.
olysteve likes this.
Shark_13 is offline
post #10 of 12 Old 09-18-2017, 09:53 PM
zipman35
We replaced my entire steering linkage last weekend. Adjusted mine 3 times and I still need to get under there and do it again lol
My steering wheel is like 10 o'clock position so I need a good 2-4 full rotations up on the drag link to center it again
The alignment was spot on. We just lined up everything with the linkage we took off the Jeep
http://www.4x4xplor.com/alignment.html
zipman35 is offline
post #11 of 12 Old 09-19-2017, 09:28 AM Thread Starter
rbaucom7266
I have done both before. Just not that much of a adjustment. Doesn't matter anyways. Getting new tires tomorrow. Going to let them do it.
post #12 of 12 Old 09-19-2017, 02:23 PM
Loukaps
Don't worry about how many rotations it takes. Drive down the road and take a good mental note where the wheel is at. Set the wheel there on flat ground. Turn the draglink adjuster untill wheel is centered. Whala your done.
TheBoogieman and olysteve like this.
Loukaps is offline
