Front tire/wheel wobble..NOT DW - Page 2 - JeepForum.com
post #16 of 25 Old 06-16-2010, 07:03 PM
Hesher420
Originally Posted by ckcamer View Post
Have the parts ordered. Will do the install either Friday night or Saturday.
How much did the parts cost you?
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #17 of 25 Old 06-17-2010, 01:47 PM Thread Starter
ckcamer
I got the bearing for $97, also got the sockets I needed and a smaller torque wrench for the bolts that only need 11 ft lbs. Total was 136...plus three day shipping, came out to 165 all together. The bearing is maunfactured by National, not sure how good it will be...will let you know if there are any issues with it.
ckcamer is offline
post #18 of 25 Old 06-17-2010, 01:51 PM Thread Starter
ckcamer
Originally Posted by junder28 View Post
It seems random and is not all the time but i dont even know what to look at.
Steal away...I am 90% sure my problem has been solved! If you have not already jacked up the front end and try to wiggle the tires. That should tell you if it is in the suspension the bearing or ball joints. Sounds like you may have the dreaded death wobble that, from what I understand, is very tough to track down.
I am fairly new to the Jeep troubleshooting/repair arena since so far mine has not had many issues (looking for the knock on wood emoticon).
ckcamer is offline
post #19 of 25 Old 06-19-2010, 12:39 PM
dragginwagon406
I was getting DW that started as an imbalance but at about 40 mph, it would turn into full blown DW. I had the tires balanced but it continued to wobble. I found that the frame end of the track bar had some play in it. Replaced it this morning, still has the small vibration at 40 mph but it does not escalate into DW.
dragginwagon406 is offline
post #20 of 25 Old 06-19-2010, 12:59 PM
junder28
I really dont think its DW because it has not gotten worse and there seems to be no play i the steering. Maybe i lost a wheel weight???
junder28 is offline
post #21 of 25 Old 06-19-2010, 01:49 PM
dragginwagon406
Mine had absolutely no play in the steering either. With the engine running, have someone steer it back and forth and watch both ends of the track bar, ball joints, etc.
post #22 of 25 Old 06-21-2010, 12:21 PM Thread Starter
ckcamer
Just an update, wheel hub assembly is about the easiest thing in the world to replace. Took me all of an hour and a half. The old one was definately failing. Still have a bit of a wobble but everything is tight with the steering and tire. I am assuming this is due to the fact that the tire is no longer round due to uneven wear from the bearing going out and low air pressure. Next on the list is a set of new tires!!
ckcamer is offline
post #23 of 25 Old 06-21-2010, 01:13 PM
chefdab
To those of you that have replaced the wheel bearings, what was your approximate mileage when they went bad? I have a little shimmy in the steering at highway speeds. This is not the first time either. The last time I had the tires rotated and an alignment done. The tire that was on the front passenger side was out of round. That is now my spare. After that it seemed to go away. But now the front passenger tire has a slow leak at the bead from the wheel getting hit on a rock. So I'm trying to see if my current shimmy is just because of the tire pressure difference from left to right or something else like the bearings. I have less than 35k and I would think that the bearings would last a little longer than that.
David
2005 LJ w/ RE 5.5 LA riding on 35"MT/Rs
"Roads, where we're going we don't need roads."
... at what point has "NEED" ever come into play when it comes to Jeep upgrades
Originally Posted by ranmannm View Post
I'm a idiot so be genital.
chefdab is offline
post #24 of 25 Old 06-21-2010, 01:22 PM Thread Starter
ckcamer
I bought my TJ with 100k on it and it now has 145k. If you look back in the thread there is good info on how to check to see if it is the bearing or not. Now that I have replaced the bearing the wobble/shimmy I had is 99% gone, I know the rest is due to the same problem you have, a slow leak in my tire and lack of balancing.
I would assume your problem would go away with a tire balance but take a minute to jack up the front end and see if anything else is loose.
Good Luck!
ckcamer is offline
post #25 of 25 Old 08-27-2013, 12:48 PM
Red_YJ
This thread has helped me a lot. My Jeep wobbles at the left front wheel between 42 to 49 miles per hour. Then is smooths out again. I balanced and re balanced that tire. Then I switched to the spare and there was still shaking between 42 and 49 miles per hour. Then I rotated to see if the vibration would move to a different wheel. Nope, it was still there. Well, this thread has answered a question and I am buying the new unit bearing after payday. This will be the end to a long annoying headache.
Red_YJ is offline
front , tire , wheel , wobble
I did a very stupid thing. (wobble in rear wheel/tire) rmv42158 TJ Wrangler Technical Forum 46 03-26-2010 12:21 PM
front tire wobble scottcha TJ Wrangler Technical Forum 13 03-11-2009 10:20 AM
Front Wheel Wobble!!! Greasy_ja YJ Wrangler Technical Forum 24 04-10-2008 12:58 AM
front wheel wobble... rcarchie YJ Wrangler Technical Forum 3 01-05-2006 06:56 AM
Right front wheel/tire wobble? skeletor YJ Wrangler Technical Forum 10 11-09-2005 10:31 AM
