Front sway bar end links ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Front sway bar end links ?
All Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 04-01-2015, 08:30 AM   #1
naturalgas
I need new sway bar links in front. No wheeling. Should I get the moog greaseable that are a bit more exspensive or just buy the cheapies? Also is Rock Auto the best price for these? I have a 04 LJ. Thanks in advance.
naturalgas is offline   Reply With Quote Quick reply to this message
Unread 04-01-2015, 08:33 AM   #2
JBTJ
Do you have a lift installed?
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 04-01-2015, 08:35 AM   #3
JBTJ
The OEM links are crap. Zone Offroad makes some solid links that are far better than stock.
Unread 04-01-2015, 08:36 AM   #4
naturalgas
no lift. just 31's
Unread 04-01-2015, 08:47 AM   #5
JBTJ
Originally Posted by naturalgas View Post
no lift. just 31's
Check out http://zoneoffroad.com/zone-offroad-...cherokee/j5300
Unread 04-01-2015, 08:51 AM   #6
naturalgas
will do
Unread 04-01-2015, 12:48 PM   #7
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Just buy cheap solid links. Check Ebay.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
TheBoogieman is offline   Reply With Quote Quick reply to this message
