#1 | |
Front Sag - aluminum spacers
Hey guys I have the RE 3.5 superflex lift and after installing my superwinch 8500lbs and an aftermarket bumper my front is sagging a little. I found this set of spacers on red rock 4x4. anyone have this setup and do you know if these spacers will work with the RE springs?
http://www.redrock4x4.com/shop/products/535.html thanks! ![]()
Black Jeep Society Member #398 *Jeep Wave* |
#2 |
bump for an answer?
#3 |
Demonic Jeep Freak!
Why not just get the poly spacers for cheaper and yes they will work.
#4 |
Or go gucci and get the JKS ACOS spacer system. Pretty sweet.
#5 | |
Straight Up Fool!
I'm pretty sure the minimum adjustment on the ACOS will be too high for what he is trying to do.
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad I drive on the right side, what's wrong with you? Quote:
#6 |
#7 | |
Straight Up Fool!
Check around on pricing too, a poly spacer is a poly spacer... I know RC sells some too.
#8 |
Wahoowa
Those aren't ACOS though. Those spacers would work perfectly fine.
White 01 TJ Sport 4.0 NV3550 |
#9 | ||
Straight Up Fool!
Perhaps I was mistaken, I remember seeing a set of ACOS that were for 1.5-3", that would be too much even set at the minimum of 1.5".
#10 |
i will look around. I heard somewhere poly spacers wear down or deteriorate over time? also can i feel fairly confident that almost any spacer will work with my springs?
#11 |
TJ Wrangler, 1997-06
Location Range Qty Part # Price Front 1.5" - 3.75" Pair PN 22001 $263.00 Rear 2" - 3.375" Pair PN 25501 $263.00 Whoops. It's 1.5" min adj. |
#12 | |
Straight Up Fool!
If they are for a TJ, they will fit your springs.
#13 | |
Straight Up Fool!
That was my point!
#14 |
great thanks guys
#15 | |
Demonic Jeep Freak!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
