> Models
> Jeep Wrangler Forums
> TJ Wrangler Technical Forum
Front rubi 44 Ox locker in a standard rear 44
06-19-2012, 11:26 PM
#16
Originally Posted by Jasons4x4
That's good, but OP is asking about installing a *front* rubi 44 locker in a regular 44 rear.
Sorry I didn't explain all the details... I should have said,
Local gearshop installed my rear rubi locker into a standard d44 rear. And since many people put a front rubi locker into their rear rubi housing... then the front and rear lockers are interchangeable. To continue further... if the OX locker fit in the front Rubi housing, It will fit the same in the rear... any modifications that were made for it to fit in the front housing will need to be made to the rear housing to install it.
Also... the OP was asking about an OX ( non factory ) locker that is currently installed in a front Rubi housing fitting in a Rubi rear housing.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
.[URL="http://www.jeepforum.com/forum/f194/dcope17s-thoughts-bible-please-read-only-do-not-post-1333441/#post13115090"]My Bible Thread[/URL]
06-20-2012, 06:56 AM
#17
Back From The Ashes
Did you read the OP's original post including the title of this thread?
06-20-2012, 07:54 AM
#18
Oh yeah, to answer the question.
Yes it will fit. But its still a peice of sht.
But at least you are local and go directly to their shop and ask for the parts to put it back together when the case half bolts back out and locker comes apart into two halves like all the 44 OX's I've seen. Which was three in a row.
Good luck.
06-20-2012, 07:56 AM
#19
Good luck.
Friend of mine had this happen to his front OX; he caught it before the locker came apart, but not before the loose bolt(s) ruined his gears.
06-20-2012, 08:03 AM
#20
Yeah they do that.
ARB's used to do it as well but they updated their stuff.
I dont know if OX has done the same. We gave up on them after the 3rd one that came apart.
06-20-2012, 08:39 AM
#21
Back From The Ashes
Yeah they do that.
That is clearly an installation error. OX has had a really hard time getting people to read the directions. You must use red loctite on the case bolts after you drop the ring gear on to the carrier. And that also means proper prep before applying the loctite.
06-20-2012, 08:42 AM
#22
That's what my friend was hoping. He bought the Jeep with the lockers already installed, so who's to know if they were properly installed or not. They've since been properly fixed and have been working fine, but it hasn't been that long yet. Other than that, it's the only issue he's had with them.
06-20-2012, 08:44 AM
#23
I have only seen one OX have the bolts back out. Guess what? No loctite.
NEW CV DRIVESHAFT FOR SALE
1997 TJ - Current project: Simple build --> LCG, 35s
1988 Civic Hatch - Runs 12's, gets 30 mpg
06-20-2012, 09:07 AM
#24
Doesn't matter how much loctite you use on ANY of the lockers of that design be it ARB, Detroit or OX.
If the bolts don't back out, the heads will snap off. The problem is the Dana 30 housing and how much preload you have to build into the carrier bearings to help support the locker halves. So no, loctite won't fix it.
I am Savvy
blackmagicbrakes.com
06-20-2012, 09:25 AM
#25
Go ahead and correct me where I'm wrong... here's how I understand this thread.
OP's friend has his old Rubi axles sitting in his garage and the front axle has a non factory OX locker installed in it. The OP wants to know if he can install that locker in his rear non-rubi d44.
I guess I either misunderstand the thread or my use of "if A=B and B=C then A=C" logic is confusing some.
06-20-2012, 09:35 AM
#26
Back From The Ashes
/\ This is correct
Local gearshop installed my rear rubi locker into a standard d44 rear. And since many people put a front rubi locker into their rear rubi housing... .
/\ This is not what the OP is doing
/\ This is not confusing, just not what the OP is asking.
06-20-2012, 09:49 AM
#27
/\ This is correct
Deductive reasoning. Follow the logic...
06-20-2012, 09:55 AM
#28
Back From The Ashes
Pot stir'r...  Aren't we talking about D44's here?
06-23-2012, 01:33 PM
#29
Yeah they do that.
What selectable lockers do you use since the two most highly regarded selectables ive read about are garabage according to you??
Or are you a detroit/aussie guy?
Not hating on those i love my aussie i just want selectables.. and from what ive read the other selectables are nothing to get excited about, eatons have their problems, the auburn ected are going to wear out over time, its inevitable.
On another note thanks guys for all the help!! Maybe ill get locked and regeared by the end of summer or so but well see.. Might be buying a yj this week to part out.. just waiting for the owner to accept my offer.. if all goes well with that i should have the money to fix all this.
2002 TJ 3.25" RC lift, 1.25 BL, MML, 33X12.50 Goodyear MTR w/ Kevlar, adjustable front trac bar, cut stock bumper, poison hood louver, B&M short shifter, chromoly rear axle shafts in the d44 4.88s Grizzly locker, Aussie locker up front in d30,10,500lb winch w/ synthetic rope, antirock, jcr sliders, savvy arms
Work harder, thousands of people on welfare are counting on you.
[URL="http://www.jeepforum.com/forum/f22/ssquier92s-02-tj-build-thread-1142141/index4.html"]http://www.jeepforum.com/forum/f22/ssquier92s-02-tj-build-thread-1142141/index4.html[/URL]
