Front Relocation Bracket - JeepForum.com
post #1 of 13 Old 06-27-2010, 01:40 AM Thread Starter
jeepxguy_02
I went to use my JKS quick discos and it seems the shop I took my jeep to recently installed a relocation bracket for the steering stabilizer and connected the track bar where the steering stabilizer was. (I was getting adjustable front track bar installed) It prevents me from being able to disconnect my sway bar on the passenger side. Anyone ever heard of this? I am calling to get it fixed Monday. Pics below
jeepxguy_02 is offline
post #2 of 13 Old 06-27-2010, 01:53 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
that is the skyjacker adjustable track bar kit.
Mail crawling.
MisfitSeven is offline
post #3 of 13 Old 06-27-2010, 02:03 AM Thread Starter
jeepxguy_02
well it doesn't work with the jks discos. i have to take the bracket off and mount the track bar where it was originally. thanks.
post #4 of 13 Old 06-27-2010, 02:04 AM
MisfitSeven
MAiL Crawler.
do you still have your stock track bar?
Mail crawling.
post #5 of 13 Old 06-27-2010, 02:09 AM Thread Starter
jeepxguy_02
No. I am calling the guy that did it and he will have it fixed. Didn't pay him to do this BS. lol So he can fix it.
post #6 of 13 Old 06-27-2010, 02:45 AM
MisfitSeven
MAiL Crawler.
adjusting an adjustable track bar isnt all that hard to do by yourself.
that skyjacker kit is one of the more expensive kits out there. thats probably why he put it on your TJ.
good luck.
Mail crawling.
post #7 of 13 Old 06-27-2010, 12:35 PM Thread Starter
jeepxguy_02
So you can take off the bracket and just bolt the skyjacker track bar in its original location below the axle? If so it I might just take a trip to ACE hardware to get some new bolts and re-mount it myself. Thanks again.
post #8 of 13 Old 06-27-2010, 01:31 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
im confused. why would you need this bracket? it doesnt look like you've changed your steering geometry, so relocating the track bar mount is a really bad idea. and better yet, why would you pay someone else to install a track bar. its only two bolts and a jam nut. front track bars are very easy to install, the only crazy items you need are a BFH and torque wrench. you dont even need to lift the jeep off the ground.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #9 of 13 Old 06-27-2010, 01:33 PM
MisfitSeven
MAiL Crawler.
no. it is shorter than the stock one. that is why i asked if you still had it.
the SJ TB a good setup. i dont know why you are so in love those particular discos.
Mail crawling.
post #10 of 13 Old 06-27-2010, 01:35 PM
MisfitSeven
MAiL Crawler.
because the SJ TB mounts in the stock SS location.
Mail crawling.
post #11 of 13 Old 06-27-2010, 01:38 PM
jeepinmichguy_
those disco's are easy.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #12 of 13 Old 06-27-2010, 01:40 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I bet it comes with a nice drop pitman arm as well. Raising the axle end of the trac-bar and lowering the frame side of the drag link. This will cause bumpsteer and is not a good idea.
xjfever is offline
post #13 of 13 Old 06-27-2010, 01:42 PM
Unlimited04
yes, i can see that.
the question is why? why would this be favorable? why add more brackets and geometry changes when you don't have to? why create interferences when there is no reason to? (Whether that be JKS, or SS, or extra bumpstop height needed to clear at full stuff)
Useful Write-Ups:
Funny:
skyjacker , track bar , quick disconnects
Front trackbar relocation by drill and rear trackbar relocation bracket install? loudog3114 TJ Wrangler Technical Forum 20 10-26-2014 08:01 PM
Front Trackbar Relocation Bracket Jeep1067 TJ Wrangler Technical Forum 19 01-28-2010 06:32 AM
3" Lift - Trackbar relocation bracket - front azcoyote TJ Wrangler Technical Forum 7 10-19-2007 01:35 PM
Best value in a track bar relocation bracket? Rear relocation bracket? STW TJ Wrangler Technical Forum 9 02-26-2007 07:58 AM
JKS trackbar relocation bracket (front) BNovak TJ Wrangler Technical Forum 0 11-16-2006 06:55 PM
