Front Pinion Angle? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Front Pinion Angle?
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 11-14-2005, 03:27 PM   #1
BaileyAZ
Front Pinion Angle?
I have done a couple of searches and all the posts have addressed the rear angles, but what about the front? Is it the same as the rear? +/- 1*?
BaileyAZ is offline   Reply With Quote
Unread 11-14-2005, 03:30 PM   #2
TJ on the Rocks
You need to be concerned that the castor is correct , this is why you won't see too much if any thing on the front pinion angle . Proper castor angle takes precedence over pinion angle . And if you're referring to a TJ then your front shaft is way longer than the rear shaft any way .
TJ on the Rocks is offline   Reply With Quote
Unread 11-14-2005, 07:33 PM   #3
igofshn
Locked @ both ends
igofshn's Avatar
Front isn't a problem because of the longer driveshaft.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
[Jeep Pics
igofshn is offline   Reply With Quote
