front lower suspension arm sheared off... seek advice
#1 | |
So I switch vehicles with my girl for a day and when I get it back this is what I find:
![]() It looks like I need a new axle tube to fix this little situation. Any heavy duty replacements out there? the suspension arms look pretty weak too, might replace those while I am at it.
#2 |
You can get the brackets from Rubicon Express - a lot beefier than stock. you don't need a new axle tube. I tore one of mine off a couple weeks ago and had a fab shop put the RE brackets on both sides and also boxed them in with skids. They ain't gonna rip off now. Sorry - no pics. If you are going to replace the control arms get some that flex such as RE Superflex.
jim
03 Sport |
#3 |
Thanks otis! I'll look into that.
#4 | |
Do it right or not at all
![]() Join Date: Jan 2003
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#5 |
is it driveable like that?!
how did it get home???
[CENTER] 98 tj ar23's with 31's 4.10 gears [COLOR=Red]red jeep club member #283[/COLOR] [/CENTER] |
#6 |
I just put in Currie's
They were $40 for the set, and I added the mini-skids as well![]() Tam
My Jeep Rocks! |
#7 |
Hello everyone,
May I ask a question on this subject. I am currently rebuilding my front and rear diffs. and have the axles off the jeep. If I were to make the factory welds stronger by welding both sides of the bracket rather than just on one as the factory do would this be sufficiant? I won't be rock crawling which is what I presume puts the stress needed to break the brackets. But I do have the skyjacker lower control arms fitted. Thankyou to any replies. Regards, Steve B |
#8 |
Steve B-Since you have the axles off now, why not order a set of the replacement brackets and skids, weld them up; and be done with it. Your idea of welding both sides would improve it-but you still only have the "tin-foil" thickness of the bracket to worry about.
Rock crawling alone is not what tears them off. Anything can do it. Stump, log, frozen clumps, rocks, etc. Just a weak point in Jeeps. Note, they can also be torn off without hitting something, but that is the normal cause. |
#9 |
Yea Steve B it's the metal that usually rips not the weld. It was the same with mine. That metal is really thin.
jim
03 Sport |
#10 |
JEEP FREAK
If you still will be using your cam bolts, another option for replacement heavy-duty brackets is Rusty's.
I don't think the RE or Currie brackets have provisions for cam bolts.
98 TJ |
#11 |
Thanks guys, will do it properly
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
