Front lower control arm brackets - JeepForum.com
post #1 of 7 Old 06-07-2008, 08:22 PM Thread Starter
ce7vin
I got back from a wheeling trip today and noticed my axle front axle is shifted 2 inches towards the drivers side. Looked underneath it and the lower control arm brackets are super shot pass side about to snap off.
Ok so my question is I've been looking aftermarket brackets and was curious as to if youre better off going with factory style brackets with the castor slots or rubicon express type without the slots. Seems to me that youd be better off with the slotless???
ce7vin is offline
post #2 of 7 Old 06-07-2008, 09:03 PM
never monday
you are correct, but you'll need adjustable upper arm to correct the castor.
never monday is offline
post #3 of 7 Old 06-07-2008, 09:14 PM
Sweeney
If you have adjustable arms up front, get the non-adjustable brackets. If you don't have adjustable arms and don't intend to get any then get the brackets with cam bolts.
Sweeney is offline
post #4 of 7 Old 06-07-2008, 09:35 PM
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Rusty's has some good control arm parts under builder parts.
http://rustysoffroad.com/mm5/merchan...egory_Code=cus
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
post #5 of 7 Old 06-08-2008, 01:14 AM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Forget about the cam adjusters... just get the beefiest mounts you can find. Adjustable control arms will give you whatever adjustment you might need.
I'll be Savvy someday!
neZZr is offline
post #6 of 7 Old 06-08-2008, 04:43 PM Thread Starter
ce7vin
control arm mounts
Yes I guess I should have mentioned all of my control arms are adjustable upper lower front and rear. I have another question to add as well. With the adjustable arms what is the ideal legnth for a 4" lift short arm? I dont remember my measurements but my front trac bar is hitting the top bolt head on my dif cover and the tie rod barely clears the tracbar at axle mounting point. Should I shorten the control arms?
ce7vin is offline
post #7 of 7 Old 06-08-2008, 07:09 PM
neZZr
neZZr's Avatar
Possibly. I never had a problem with my trackbar hitting the diff cover after I lifted... in fact, I had that problem and I lifted to solve it. If it only makes contact at full stuff, just add a bit more bumpstop. The tie-rod will always be very close to the swaybar link on the passenger side, but an upgraded steering setup like the one from Currie has a bit more clearance built-in... and it's a worthwhile upgrade that you'll probably need eventually anyway with larger tires.
neZZr is offline
pic's of front lower control arm brackets clearanced timritchieblue TJ Wrangler Technical Forum 0 12-16-2009 07:29 AM
dana 30 lower control arm brackets 2000jeeper TJ Wrangler Technical Forum 5 08-01-2009 09:05 PM
Lower Control Arm Drop Brackets bfaneros TJ Wrangler Technical Forum 34 12-22-2008 07:21 AM
Lower Control Arm Brackets Issues fisher836 TJ Wrangler Technical Forum 3 03-24-2008 05:03 AM
Lower And Upper Control Arm Brackets 95cuin TJ Wrangler Technical Forum 3 12-10-2007 06:59 AM
