Quantcast front end u-joints - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > front end u-joints
Poison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 01-27-2008, 03:45 PM   #1
UTmike
front end u-joints
I've been noticing whenever I accelerate a little hard I hear a couple clicks coming from underneath me towards the front of the jeep. The harder I accelerate, the harder the clicking. It sounds almost like it's coming from the driver front axle u-joint, but it's hard to tell for sure since I'm in the vehicle. Do axle ujoints click like that before going out? I wouldn't think so b/c I'm not stressing the front axle while in 2wd, so they shouldn't be clicking. What about the front driveshaft ujoints? But I wouldn't think they're under stress either in 2wd???
4.5" RE SF Lift, 1" BL, 35" Cooper Discoverer STT, Lockrite Locker, 8.8 Rear, AA SYE, Tom Woods DS, Sliders, Skids, Bumpers, Rear Stinger, RockCrusher Diff Covers, 8000# Winch, Herc'd Tub, Homemade Deck Cover, On Board Misting System and Faucet
UTmike is offline   Reply With Quote
Old 01-27-2008, 03:48 PM   #2
Kiwi Jeeper
Is it a clicking sound definitely?
Otherwise it could very well be the bushing on the anti-sway bar. When you accelerate, weight shifts to the rear and the front left end lifts up a little (thats how a TJ engine rotates). Its a possibility.
Kiwi Jeeper is offline   Reply With Quote
Old 01-27-2008, 04:13 PM   #3
Dogman
I had a clicking sound that was driving me crazy. It would happen while turning sharp and also when I would first accelerate from a stop. It was my passenger side u-joint.
Get down there and grab ahold to see if you can feel any play in the joint.
Dogman is online now   Reply With Quote
Old 01-27-2008, 04:54 PM   #4
McLovin
1991 XJ Cherokee
yep check your U-joints, they dont last forever. Be sure to buy genuine spicer 760x's. The house brand u-joints like napa and autozone dont seem to hold up well to our off roading and bigger tires. I also prefer sealed over greaseable.
http://jeep4playoffroad.org/index.php --your local oregon coast club
McLovin is offline   Reply With Quote
Old 01-27-2008, 05:09 PM   #5
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
Just courteous, how many miles do you have on your rig?
2009 JK Rubicon.
Auto, Skid Row Engine Skid, Lower Control Arm skid & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Differential Skid Front & Rear; 11,000# Pull-Pal, Uniden 520XL CB with 3' FireStik Whip.
Shrockworks Mid-width Front Bumper with Warn 9.5Ti -- Ordered 7/17/2009; Bumper Received 12/4/2009.
Visit here to view my wheeling Pics: Moab-4/2006, 5/2008, 4/2009, 5/2011; Ouray-8/2007, Rubicon-9/2008.
http://community.webshots.com/user/thunder1strike
Thunderstrike is offline   Reply With Quote
Old 01-27-2008, 05:18 PM   #6
UTmike
about 70,000
I'll have to check for play in the ujoints then. I know my front drive shaft has about half an inch of play in it, but it's not at the ujoints. Is that normal?
Old 01-27-2008, 06:49 PM   #7
CNY
What king of play? Rotational?
CNY is offline   Reply With Quote
Old 01-27-2008, 06:54 PM   #8
Kiwi Jeeper
There will always be some rotational play in the front driveshaft as NP231 is a chain driven transfer case. As long as there is no play between the components on the driveshaft itself, it should not raise any alarms within reason.
Old 01-27-2008, 06:58 PM   #9
UTmike
Yeah, it's just a little rotation and it's not across the ujoints. I'll give the axle ujoints a look at.
Old 01-27-2008, 07:46 PM   #10
McLovin
1991 XJ Cherokee
about 70,000
I lost my first U-joint at 38,000 miles FYI
Old 01-29-2008, 05:24 PM   #11
UTmike
I found some that are spicer 5-760x. that's the one's right?
Old 01-29-2008, 09:00 PM   #12
Dogman
Yep...Have you seen the write-up on Stu's site?
Old 02-06-2008, 07:37 PM   #13
UTmike
Well all my ujoints feel solid up front. I noticed that the bushing on the pitman arm was warped and lopsided. Can these pop when they're worn and need to be replaced? I'm gonna order a ujoint too just in case though.
Old 03-25-2008, 05:52 PM   #14
UTmike
To update: I replaced both the front axle shaft ujoints last week and to my disappointment, the problem was still there, unchanged. I've also noticed that it doesn't click as badly or at all when it's real cold outside but does it a lot worse when the temp gets up to the 60s and 70s. I also had someone stand outside while I hit the gas and they thought the clicking was coming from a little further back, around the xcase or transmission. So to bring up the question again, the front driveshaft shouldn't be under stress while accelerating in 2wd right? So the front driveshaft ujoints shouldn't be clicking louder and harder, the harder I hit the gas if it were them, right?
Old 03-25-2008, 06:16 PM   #15
daveg13
Did you check your trans. mount?
daveg13 is offline   Reply With Quote
Glock Forum
