Front end squeaking/ scraping (brakes?) - Page 2 - JeepForum.com
post #16 of 19 Old 08-31-2013, 08:07 AM
SlackJaw
baby jeep
SlackJaw's Avatar
Yes there are. If you put them on the wrong side, they are upside down on the bracket. The 2 tabs go on bottom, while the one tab goes on top.
This could almost certainly allow at least the piston side pad to move more under forward braking than it would if on the correct side.
The piston side has a spring that goes in the piston, and the outside pad has 2 buttons that seat in 2 holes. They all have 2 tabs on one side an only 1 tab on the other. The 2 tabs are supposed to be on the bottom bracket.
Think about that for as long as you need, and you'll find although they CAN be installed 2 ways, there is only one CORRECT way you can achieve it.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #17 of 19 Old 08-31-2013, 09:14 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by Benderff View Post
I wouldn't go back to that shop.. Ever...
Don't bring to me then either. I warrantied a set of our pads that the customer said was squeaking and our pads don't squeak. I have them ship them to me and see that the backers have been bowed enough that it cracked the friction layer. A bit more examination revealed they had been run upside down.
I can only guess that the slotted end locked into the divots easier and then caused the backer to bow.
Anyway, the easy way to remember how to install them correctly is to remember to set the caliper with pads on the lower slider first and then rotate the top in.
As for it not being possible, I've got a rig in the driveway right now that I just swapped the pads side to side because they were on backwards, so it does happen and probably more often than we know.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #18 of 19 Old 08-31-2013, 09:20 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
You are correct on most things with the exception of them being able to be installed 2 ways. There is a variable that involves taking the number of pieces that are unique and then using that number as a power to find the total number of variations. I don't remember how to do that exactly but I can easily let you do some math for me.
The inner pad on both can be up and down.
The outer can be both up and down.
Both can be up, both can be down.
1 can be up and 1 can be down on the same caliper.
Don't laugh, I've seen it and sat there a few minutes trying to figure out how to get it back apart and fix it and darn it if the other side wasn't the same way.
I am Savvy
mrblaine is offline
post #19 of 19 Old 08-31-2013, 05:07 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Certainly there are more combinations...I would think one would have to be clever enough and/or work hard enough to get them on that way such that it should be pretty obvious that something is wrong.
SlackJaw is offline
brakes , dragging , front , sticking
