Quantcast Front End Clunking - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Front End Clunking
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comPoison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.
Old 07-13-2007, 12:17 PM   #1
BlueTeeJay
My other ride's a tractor
BlueTeeJay's Avatar
Front End Clunking
For the past week I've had this "clunking" going on.
It's up front and only when I hit bumps. I can get on the front bumper and move the Jeep up and down with no noise.
All the bushings look fine and I just replaced the control arms.
See pics....
It's the only thing that doesn't look right to me.
Help?
BlueTeeJay is offline   Reply With Quote
Old 07-13-2007, 12:19 PM   #2
Chris @ GATR
What about these pictures looks abnormal?
Got ignorance? Please see below.
[QUOTE=kd4yor;4763909]Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).[/QUOTE]
Chris @ GATR is offline   Reply With Quote
Old 07-13-2007, 12:24 PM   #3
BlueTeeJay
BlueTeeJay's Avatar
The imprints where they're hitting. No?
Old 07-13-2007, 12:26 PM   #4
Dravintoad
Nope, those are from where your bumpstop, stops. normal
Nothing to see here.
Move along.
Dravintoad is offline   Reply With Quote
Old 07-13-2007, 12:34 PM   #5
BlueTeeJay
BlueTeeJay's Avatar
So if that's normal.....what the heck do you think it is?
oh...and my top IS off!
Old 07-13-2007, 12:36 PM   #6
[ITA]Tsunami
Italian Wheeler in Mexico
[ITA]Tsunami's Avatar
check your anti-swaybar links. They tend to clunk if the bushings are shot. It is noticeable while going over bumps.
Originally Posted by mdm
However it is a strange twist in the cosmic thread that will not allow the driver of a Jeep that has experienced air bag deployment off-road to consume beef for 48 hours after the event. You can consume chicken, pork, turkey, or emu.
[ITA]Tsunami is offline   Reply With Quote
Old 07-13-2007, 12:53 PM   #7
Chris @ GATR
A front end clunk is very hard to diagnose over the internet, however, your main "clunk" culprits to check for would be:
Trackbar Trackbar Mounts
Swaybar links & bushings (This is my guess also)
Coil spring retainer clips
Upper and lower shock mounts
Control arm bushings
Control Arm Bolts
Old 07-13-2007, 01:13 PM   #8
fish4life
it could also be a loose shock mount. Those bar pins are crap and maybe they are lose. Give them a good check as well.
I had a clunk, mine turned out to be the sway bar links .. but that was already mentioned by someone.
fish4life is offline   Reply With Quote
Old 07-13-2007, 02:43 PM   #9
kercher
has anything changed, like lift or anything? My passenger side endlink hits where the draglink meets the tierod. There is also so rubbing on the steering damper bracket. I only get the clunk over bumps.
My Jeep: 1948 CJ2A 1948 CJ2A
kercher is offline   Reply With Quote
Old 07-13-2007, 02:56 PM   #10
jterp
I bet you $100 it's a sway bar link.
$30 @ napa.
Only hard part is getting the old one out of the sway bar. Use lots of PB blaster and a hammer.
jterp is offline   Reply With Quote
Old 07-13-2007, 03:01 PM   #11
Chris @ GATR
$30 @ napa.
To change an endlink?
Old 07-13-2007, 03:23 PM   #12
baudencm
Does it sound as if its coming from under your feet? Could be the transfer case linkage hitting the tub too. Advance Adapters make a bracket to fix it. I ordered one yesterday... Good luck!
CB
baudencm is offline   Reply With Quote
Old 07-13-2007, 03:30 PM   #13
BlueTeeJay
BlueTeeJay's Avatar
New sway bars about 4 months ago. I'll take a better look once I get it home. Thanks for the help!
Glock Forum
