Front driveshaft rubbing against exhaust pipe - JeepForum.com
post #1 of 4 Old 07-21-2010, 10:22 PM Thread Starter
clerical12
Was out in the woods last night. Heading back to the road I had to go over a mound of rocks and dirt. I believe I hit the rockers but didn't thnk anything of it. As I started on the road I heard this noise caused by the driveshaft. I checked but didn't see anything, now I know it's the front driveshaft rubbing against the exhaust pipe. Any ideas of what went wrong and how to fix this? I checked quick and didn't see any obvious signs of what happened. I will produce pictures in the AM.
clerical12 is offline
post #2 of 4 Old 07-21-2010, 10:36 PM
bigwahini
If your exhaust is hitting the front driveshaft then that should tell you what went wrong. As to how to fix it, depending on the extent of damage to the exhaust system, you could either push it over with your foot or a 2x4 or you could replace it. If it is bent enough to restrict flow, it could cause poor performance.(Sorry if that sounds like a late night commercial for a mens health product.)
ifyoubegintothinkyou'relosingcontrol...it'salready gone
bigwahini is offline
post #3 of 4 Old 12-19-2010, 01:17 AM
SixZeroAlpha
im having the same problem right now. i havent heard much, however having it on a hoist the other day i did notice it rubbing. i know it is as recent as the last engine going in so im curious as to if it was improper install of the engine or something else. ( i have been counting the things going wrong and just stopped counting at the doors. but thats another story)
SixZeroAlpha is offline
post #4 of 4 Old 12-20-2010, 02:10 AM
Yuri
Yuri's Avatar
Check your motor mounts and the track-bar. You may have broke a motor mount, or moved the axle a little further to the passenger side.
It could also be the exhaust hanger near the transfer case (that's the first hanger forward). As my exhaust got older, it hung down more on the passenger side, which caused it to move closer to the driveshaft. I just added another hanger near the upper control arm mount on the passenger side.
2001 TJ; 1999 XJ; 1993 ZJ
Yuri is offline
driveshaft , exhaust , rub , rubbing , tj , wrangler
exhaust rubbing on driveshaft GRN_BEAST95 YJ Wrangler Technical Forum 13 06-18-2009 10:03 PM
Exhaust Rubbing on Front Driveshaft veritas4156 YJ Wrangler Technical Forum 8 04-05-2008 09:05 AM
Front driveshaft hits down pipe cbmadcow TJ Wrangler Technical Forum 5 10-28-2007 02:29 AM
front driveshaft rubbing chadsmeltzer TJ Wrangler Technical Forum 13 10-01-2007 08:57 PM
Front Driveshaft Contacting Exhaust Pipe dionysius TJ Wrangler Technical Forum 4 12-05-2006 12:14 PM
