front driveshaft in the rear? - JeepForum.com
post #1 of 8 Old 11-21-2008, 12:15 PM Thread Starter
timritchieblue
i know you can run a xj shaft, but what about a tj front shaft, i need a cv?
FOR SALE:SOLD
2000 TJ 2.5" CLAYTON L.A. W/HYDROS, SYE/XJ SHAFT, 4:10 GEARS, 8.8 MINI SPOOLED, LOC-RIGHT FRONT, 1" BODY LIFT, 1" MML, 35" MAXXIS BIGHORNS, RE GEN 2DISCOs, BELLY UP, ALCOS IN FRONT, WARN X8000I
timritchieblue is offline
post #2 of 8 Old 11-21-2008, 12:23 PM
lilboy1023
I haven't heard about that. Just the "Hack N Tap" with the XJ front. I would assume, and could be wrong, that it would work since you have to cut it to length anyway.
lilboy1023 is offline
post #3 of 8 Old 11-21-2008, 12:35 PM
Si1ver03Rubicon
^ x2 after you shorten it, it should work. Dunno if the joints are the same?
Si1ver03Rubicon is offline
post #4 of 8 Old 11-21-2008, 01:22 PM Thread Starter
timritchieblue
does anyone know if the joints are 1310 on the front tj shaft?
FOR SALE:SOLD
post #5 of 8 Old 11-21-2008, 01:23 PM
lilboy1023
I believe that they are. They are both Dana 30's and they haven't changed, till the JK. Should be the same thing.
post #6 of 8 Old 11-21-2008, 03:00 PM
willness33
Yep, they're all 1310s.
willness33 is offline
post #7 of 8 Old 11-21-2008, 03:03 PM
lilboy1023
Finally, I got one right!! thanks williness.
post #8 of 8 Old 11-21-2008, 05:30 PM
gaucho919
X2, yes they are 1310's a TJ front dshaft is a perfect choice
"The journey is the destination"
gaucho919 is offline
DIY XJ front driveshaft shortening for use as rear CV driveshaft on YJ Joe Dillard YJ Wrangler Technical Forum 43 08-12-2014 08:53 PM
Help with my TJ (front lunchbox locker and rear driveshaft w/ SYE) diablo_331 TJ Wrangler Technical Forum 28 12-21-2010 11:57 AM
disco rear driveshaft, drive with front d44? MC_NickP TJ Wrangler Technical Forum 11 09-11-2009 01:27 PM
Front and Rear driveshaft upgrades? iowajeepers YJ Wrangler Technical Forum 8 03-08-2009 06:34 PM
XJ front CV driveshaft in rear after SYE Poppy360 TJ Wrangler Technical Forum 1 09-09-2004 01:33 PM
