front driveshaft pulsing vibration - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > front driveshaft pulsing vibration
4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededBead Lock Wheels! Raceline, Trail Ready, & Trail-GearJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 03-24-2011, 07:14 AM   #1
viperbluelx
Since regearing to 4.88's I've had a pulsating vibration that starts around 70mph, but you can also very slightly feel it at 45mph. I hadn't had time to mess with it till a few days ago when I took the time to disconnect the front driveshaft and tie it out of the way and the vibration is gone. The front shaft u-joints all feel good and there was no vibes with the 3.73's. Should I worry more about caster angle or driveshaft angle? With the UCF skid on I pointed the front pinion at the shaft so I'm sure caster is off but it doesn't drive bad, but could it cause a vibration? Driveshaft balance?
98 XJ 4-door, 6.5" lift, SYE, sliders, locked HP30, welded 29-spline 8.25, 35" buck shots.
viperbluelx is offline   Reply With Quote
Unread 03-24-2011, 07:17 AM   #2
pilotkc
Which type driveshaft do you have?
pilotkc is offline   Reply With Quote
Unread 03-24-2011, 07:24 AM   #3
rideraa
It may be that your are turning more RPM's now with 4.88 gears ?? And show a existing balance / wear issue that was not present at lower RPM's.
Did the tire size change to bring the rpm's back down any??
And as you mentioned, it may be driveline angles, front should be straight-shaft & pinion.
Above stuff is pretty common that you may already know, may help ??
"CHEAP HEAP" TJ, 4.0, 32rh, 1" MML, 1-1/4" BL, 4" Lift Custom LA, Discos, 3/4" front spacers, D-44 - locked 4.88 Rubi frt & rear, RCV Shafts, Superior Seals, 1 ton OTK, SYE, Tom Woods , UFC Ultra TC, Engine & Al Tank Skids, 37 x 12.5 x 15 MTRs, 32bolt 15 x 10 steel bead locks, XRC 8k winch, Cobra cb, Firestick, Joe&Rideraa Rear Bumper w/ Hitch, TSC Front Tow Points, Sliders, hi lift,full recovery gear
rideraa is offline   Reply With Quote
Unread 03-24-2011, 09:05 AM   #4
shrubeck
If you figure it out, I want to know. I've had the same problem for years. I'm just in the habit of disconnecting the front shaft before a long drive, but I would much rather fix the problem. I have 4.56 gears on 33s with front and rear woodies btw.
That's what she said.
shrubeck is offline   Reply With Quote
Unread 03-24-2011, 02:28 PM   #5
viperbluelx
Factory driveshaft in the front.
Unread 03-24-2011, 03:56 PM   #6
msiefer
Eat, Sleep, Jeep...
msiefer's Avatar
If your pinion angle looks reasonable then it is probably time to have the front driveshaft checked out and balanced. I'm just in the process of putting my 4.88s in and my driveshaft is at the local driveline shop getting a new slip spline and re-balanced. I'll let you know how it turns out.
msiefer is offline   Reply With Quote
Unread 03-24-2011, 05:04 PM   #7
Imped
Balls
Imped's Avatar
Balance.
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 03-24-2011, 05:18 PM   #8
780406jeeper
Good luck. I have had the same problem with my jeep since I lifted it. RE 4.5 Super flex, 4.56 gears and 33's. Same speed starts that pulsating vibration. I had Jeep check the stock driveshaft 2 separate times, they said it was straight and balanced. I had local shop in Mesa Az build me a whole new shaft. Same deal. Had them try rebalancing two times too. Now have a Tom Woods shaft and no difference. I installed everything on my jeep with the exception of the gears. I have played with the driveshaft angle so many times it isn't funny adding a degree up, a degree down, straight, nothing. Ultimately Tom Woods said that it is a 'balancing act' no pun intended. We want to use a thicker tube for denting resistance strength, but need a smaller outer diameter to clear the transmission and such during articulation. Based on the longer length of the TJ front shaft, there is a point in which even the most perfectly balanced shaft will start to 'flex' out of straightness when spun fast enough.
Ulitmately, I either slow down to the point it doesn't do this, or I remove the shaft.
Kevin
'78 Cherokee Chief: 360/TH400/NOS QT, '04 Grand Cherokee: 4.7/545RFE/242HD w/SYE, JK Rubi front axle, 4.56 gears, Protofab rear bumper/tire carrier
780406jeeper is offline   Reply With Quote
Unread 03-24-2011, 05:23 PM   #9
viperbluelx
Kevin
sucks to hear, too bad there aren't strong affordable hub lock-outs for the front of these
Unread 03-24-2011, 05:36 PM   #10
780406jeeper
I agree. It has been something I have wrestled with since we bought our jeep new. As soon as I have accepted that, now I have this OPDA issue eating at the back of my mind.
My jeep has 48,500 miles on it, I am on my 3rd front driveshaft with each being rebalanced at least twice. Tom himself explained the thickness/vs length, vs diameter issue. Makes sense why those super duties all have 5+ inch diameter shafts because of their length.
For what it's worth, the TW driveshaft is the best out of the three I have tried.
Kevin
Unread 03-24-2011, 05:41 PM   #11
Imped
Balls
Imped's Avatar
I don't have this problem and I have 4.88's and the stock shaft. There's a chance for all of you.
OlllllllO
Float Test Build
IndyORV
