Front driveshaft hex bolt size - JeepForum.com
post #1 of 16 Old 06-27-2013, 07:58 AM Thread Starter
DBLJ
DBLJ's Avatar
One of the bolts at the transfer case side of my driveshaft backed out. What size is it. Qtec isn't much of a help with their descriptions.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #2 of 16 Old 06-27-2013, 08:00 AM
NotURMailman
NotURMailman's Avatar
If you're talking about the bolts that hold the driveshaft to the yoke, you can get them in a package in the "Help" (Motormite?) section at most auto parts stores.
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 16 Old 06-27-2013, 08:08 AM Thread Starter
DBLJ
DBLJ's Avatar
I am, and I didn't even think of that. I figured it would be the same size as the front strap but I was wrong. Ill swing by later and check it out.
DBLJ is offline
post #4 of 16 Old 06-27-2013, 12:34 PM
rchase559
I want to say its a 5/16x24 but I could be wrong.
I know there was a lengthy thread on this in the past that I posted in that had the answer, It is a common thread size but kind of an odd length. I'll see if I can find it.
rchase559 is offline
post #5 of 16 Old 06-27-2013, 12:51 PM
jeepmutiny
1983 CJ7
Just checked my old model 20 out of my 2000 wrangler it is 1/4 NF...Jon
jeepmutiny is offline
post #6 of 16 Old 06-27-2013, 12:57 PM
Ben
Yep.
I can't remember if it's 1" or 1-1/4" though.
There's plenty of room for the 1/2" standard head bolt on the transfer case side of the yoke too. No need to get allen bolts.
Ben is offline
post #7 of 16 Old 06-27-2013, 01:00 PM
Gary2
If I am on the same bolt . An 8mm wrench is what seems to be the most popular answer but for the actual bolt size , Sorry . I ended up with a nice skinned knuckle when the 8mm wrench I was using slipped so I tried a 5/16. It very well could of just been the quality of my wrench but the 5/16 fit tighter and was able to loosen the bolt.
Now is when the math usually is posted to explain how little the difference actually is and should make no difference . Either way 5/16 is smaller , who cares. Its just another option.
EDIT: After all of that I think you are looking for the actual bolt size , oops
Gary2 is offline
post #8 of 16 Old 06-27-2013, 01:42 PM
rchase559
Originally Posted by WKdeuce
Yep.
The stock bolts are hex head flange bolts (maybe screws, I always mix the nomenclature up). There is no Allen wrench involved. I have used regular hex head cap screws but prefer the flange version so I can use a socket and ratchet rather than a open end wrench.
post #9 of 16 Old 06-27-2013, 01:46 PM
Ben
The stock bolts are hex head flange bolts (maybe screws, I always mix the nomenclature up). There is no Allen wrenches involved.
The stock bolt heads are 5/16ths with a flange andr a 5/16ths thread bolt.
All I was saying is a standard 5/16ths bolt with a 1/2" head will fit, there's no need to try to find something with a small head (like an Allen or whatever).
Ben is offline
post #10 of 16 Old 06-27-2013, 02:44 PM
rchase559
Okay. I was confused with the Allen part but that clears it up. I still prefer the flange bolts but to each their own.
post #11 of 16 Old 06-27-2013, 03:02 PM
sandfox4
i use the bolts from a precision u joint strap kit # 360-10, works great 5/16 fine thread, with a smaller head than normal
sandfox4 is offline
post #12 of 16 Old 06-27-2013, 03:45 PM
jeepmutiny
1983 CJ7
I just checked again both axle yokes are 1/4 NF I suppose there could be different yokes of the 44 I am sure is different???? Never really paid that much attention to the kit. Just bought and installed...Jon
Looked at the T/C it is a 5/16 NF U Bolt, no threads in the yoke
post #13 of 16 Old 06-27-2013, 04:50 PM
Ben
Yep. It's not the TC output yoke that has the threads, it's the centering ball portion of the double cardan assembly.
Ben is offline
post #14 of 16 Old 06-27-2013, 04:53 PM Thread Starter
DBLJ
DBLJ's Avatar
That didnt fit.
DBLJ is offline
post #15 of 16 Old 06-27-2013, 10:07 PM
sandfox4
That didnt fit.
huh... well it worked on the 01 i just did, maybe 05 is different , pull one of your other bolts and take to the parts store, was it to big ? small ?
sandfox4 is offline
