Front Driver side tire wobbling? - JeepForum.com
post #1 of 4 Old 08-29-2010, 11:54 AM Thread Starter
logan04tj
Iv replaced all the steering ends, put in a long arm kit up front and balanced the tires and my front driver side tire will wobble around 50-55 and then it goes away after that. It doesn't happen all the time just does it for a little then goes away and then does it again while driving. Any ideas of what I should od?
logan04tj is offline
post #2 of 4 Old 08-29-2010, 11:59 AM
robncar
robncar's Avatar
Are you sure the balance was perfomred well? If so, swap that tire to the other side. If the wobble continues on the left, it may be the unit bearing. If the wobble goes with the tire, it's either damaged, not balanced, or the wheel is not round (run out). Are you certain the wheel is flush to the hub?
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 4 Old 08-29-2010, 12:59 PM
wpparker
YES, do what Robncar said. This will narrow it down to your problem.
wpparker is offline
post #4 of 4 Old 08-29-2010, 02:25 PM Thread Starter
logan04tj
okay, thanks for the help.
Front Driver Side Tire Squeak.. MacK JK Wrangler Technical Forum 7 09-09-2010 08:05 AM
Front driver side squeak Gorechild TJ Wrangler Technical Forum 9 03-11-2009 11:50 AM
squeek in driver side front end wut is it? emahan01 TJ Wrangler Technical Forum 4 03-08-2009 08:31 AM
squeeking front driver side mlb2003 TJ Wrangler Technical Forum 3 01-12-2009 01:31 AM
pop or something loose on front driver side Crunchakah TJ Wrangler Technical Forum 4 11-14-2008 05:37 AM
