Front drive shaft u-joints - JeepForum.com
post #1 of 4 Old 10-13-2005, 10:49 PM Thread Starter
jeep jake
I have never done u-joints it looks pretty easy, I need to do the front drive shaft, but it looks like I need to drop the t-case skid. Is there a write up for u-joints.
Thanks
04 TJ 4.0 5-sp
35 bfg's
long arms
60's atlas ll
jeep jake is offline
post #2 of 4 Old 10-13-2005, 11:27 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Thanks
Here ya go. And no need to drop the t-case skid. http://www.stu-offroad.com/axle/driv...iveshaft-1.htm
Jerry Bransford is offline
post #3 of 4 Old 10-14-2005, 01:42 PM
Jeepin' Rock Cl
Yep, no need to remove the skid. Just jack one front tire in the air (makes rotating the shaft easy), reach from the back of the skid with your 8mm ratchet, undo a bolt, rotate the shaft, remove the other 3 bolts in this manner. Front bolts are easy to reach.
Jeepin' Rock Cl is offline
post #4 of 4 Old 10-14-2005, 05:33 PM
Flyinbrick
Well actually instead of jacking one front wheel up in the air, I just remove the front connection first, use a rope to suspend it in the air. Then shift the t-case from N - 4wd, to lock the shaft in place so that I can remove the rear bolts.
-Michael-
1997 TJ
White Custom Long Arm with Blue Torch Fab Stretch
Wagoneer Dana 44 Front End w/ ARB, Currie Rockjock 60 Rear w/ Detroit, 37" Baja Claws, Poison Spyder Tire Carrier, Competition Corners, Flat Fenders, Front Stinger, Full roll cage, GenRight Fuel Cell, Snyper Fab Rocker Skids
Flyinbrick is offline
no zerks on front drive shaft U joints-now what van1 TJ Wrangler Technical Forum 2 12-19-2009 06:32 PM
Drive shaft U joints bombero590 TJ Wrangler Technical Forum 2 08-02-2008 08:22 PM
u joints front drive shaft mlb2003 TJ Wrangler Technical Forum 10 02-26-2008 08:49 PM
Changing U joints in front drive shaft...HELP!! KY TJ TJ Wrangler Technical Forum 7 01-26-2005 05:38 AM
Drive shaft U-joints TwinYJ9 YJ Wrangler Technical Forum 1 10-06-2004 04:18 PM
