Front drive shaft still turning in 2WD?? - JeepForum.com
post #1 of 14 Old 12-21-2006, 11:02 PM Thread Starter
nico1
I was getting ready the snow coming and wanted to make sure everything was working with the 4WD before it hits. Everything engaged fine when I went from 2WD to 4HI then from 4HI to 4LO. No problems from 4LO back to 4HI either. Now when I switch back from 4HI to 2HI it feels like the transfer case disengages but after terrible gas mileage over the last couple days I went under to have a look. Even though it feels like the front drive shaft is disengaged it is still turning. Is this due to the front axles not disengaging from the front dif? If so what is the fix?
I am guessing something wrong with a vacuum line but again I am just guessing???
Thanks!
99 TJ Sport, 2" BDS Lift, 1.25" JKS BL, 1" JKS 1" BMML, 32" BFG/AT, TKH Fab Front Bumper, Sirus Satellite Radio
nico1 is offline
post #2 of 14 Old 12-21-2006, 11:06 PM
SecondTJ
SecondTJ's Avatar
there are no vaccuum lines in engaging the TJ transfer case
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #3 of 14 Old 12-21-2006, 11:11 PM
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
i took mine out for better fuel economy.... not really, but i did take it out.
If i'm correct, the front DS turns no matter what. it is driven by the front axle, and basically is in neutral as far as the t-case is concerned.
but i could be wrong
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Jakemd98 is offline
post #4 of 14 Old 12-21-2006, 11:13 PM Thread Starter
nico1
So is there anything in place on the TJ up front that disengages the front axels from the dif to stop the front drive shaft from spinning or does it allways spin even in 2wd?? Sorry just trying to understand the setup. Thanks!
nico1 is offline
post #5 of 14 Old 12-21-2006, 11:21 PM
The Mean Fish
The Mean Fish's Avatar
You would need some sort of locking front hub kit to disengage your front axle shafts.
Originally Posted by 84 CJ7 View Post
The Mean Fish you seem to hate big business and love big government. My guess is you are drinking the coolaid that Pelosie, Reid, Barny Frank, Biden, and Obama are serving.
The Mean Fish is offline
post #6 of 14 Old 12-21-2006, 11:21 PM
SecondTJ
SecondTJ's Avatar
as i understand it, the front driveshaft turns even when in 2wd, its just not engaged
SecondTJ is offline
post #7 of 14 Old 12-21-2006, 11:29 PM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
That's right.
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
post #8 of 14 Old 12-21-2006, 11:31 PM Thread Starter
nico1
Ok, sounds like everything is normal then. Thanks for answering my dumb questions.
nico1 is offline
post #9 of 14 Old 12-22-2006, 12:02 AM
harpo1
You have automatic hubs so the drive shaft turns all the time.
98 TJ Auto 4.0L
35X12.50 SuperSwampers
4.5" Teraflex lift w/long-arm upgrade
Teraflex 4:1 Transfer with Extreme Short Shaft SYE
ARB Lockers w/4.88 Gears
Poison Spyder Trail Cage
harpo1 is offline
post #10 of 14 Old 12-22-2006, 01:16 AM
sryan2k1
Automatic hubs would be the electronic locking type, our TJs have permanently locked hubs, which is why the drive shaft always spins, and which is why it can be thrown into 4wd at almost any speed, since the hubs don't have to lock
sryan2k1 is offline
post #11 of 14 Old 12-22-2006, 04:30 AM
Brew461
Side bar here.
What kind of Gas mileage increase do people see when the warn manual hubs are installed?
Brew461 is offline
post #12 of 14 Old 12-22-2006, 05:01 AM
Overdrive
They are called drive flanges on a TJ. There is no lock/unlock. The hubs are attached to the axle by the flange.
Overdrive is offline
post #13 of 14 Old 12-22-2006, 05:35 AM
stedwest
Originally Posted by brew461
Side bar here.
I talked to one local, who said his locking hubs made no difference in fuel mileage. Look at his set-up, however, and you'd know that his rig isn't built for gas mileage anyway...
2003 SE, 4.88's, Yukon axles, Rancho springs, JKS Disco's & MML, RE trackbars, ZJ steering, and a bunch of other stuff my wife hasn't found out about...
stedwest is offline
post #14 of 14 Old 12-22-2006, 08:19 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Drive flanges are typically used to replace a locking hub on vehicles so equipped.
There are no locking hubs on TJ, thus no drive flanges.
It's a unitized bearing assembly just like a front wheel drive mini-van has.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
Can I remove the front drive shaft and still drive around? CobraKhan TJ Wrangler Technical Forum 58 11-12-2014 04:28 PM
Driver Front rotor/ shaft not turning 95wrangler4life YJ Wrangler Technical Forum 1 03-14-2009 08:02 PM
Front shaft is turning BUT wheels are not! OH-ZJ-IO YJ Wrangler Technical Forum 11 01-28-2009 05:59 PM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 03:33 PM
Can I disengage the front drive shaft if I have the Warn front axles? Nucklez YJ Wrangler Technical Forum 11 04-13-2006 10:53 AM
