front drive line issues - JeepForum.com
post #1 of 5 Old 01-06-2006, 04:50 PM Thread Starter
RED107
A couple of week ago I was hearing a squeel coming from my front drive line. It went away and a few days ago it came back. Well I took off the front drive line and found some bad u joints and a bad cv joint. I took my drive shaft to florida power train and they replaced all the all of the above. I installed my drive line yesterday and today I notice a decent vibe. With the front drive line installed there is a vibe take it off the jeep ride smooth as ice. Any idea what this could be?
02 Sport 4.5 Inch Rubicon Express Long Arm
15X8 American eagle 185 w/35/1250/15 BFG KM2's, BushWacker Pocket 6 inch Fender Flares
Warn Bumpers Front and Rear Warn XD9000I /rear Disc
RED107 is offline
post #2 of 5 Old 01-06-2006, 04:59 PM
Dusty1718
Dusty1718's Avatar
check to make sure the u-joint is not binding up. Front driveshaft could also be bent or out of balance.
-Dustin
Chrysler/Jeep/Dodge Master Technician
Dusty1718 is offline
post #3 of 5 Old 01-06-2006, 05:24 PM
otisdog
2008 WK
Have you tried it both ways on the yoke? If not try flipping it 180* on the pinion yoke.
jim
08 Grand Cherokee Overland
otisdog is offline
post #4 of 5 Old 01-06-2006, 05:32 PM
phish832
jus curious, that squeel comes and goes in my jeep too when i accelerate fast. can you describe more on what that was exaxtly?
2004 Rubi, 5.5" RE TL LA, Bilstein 5100's, 35" Pitbulls, RCV's, Currie AR, Warn Zeon
2013 GC HEMI
2015 Duramax
phish832 is offline
post #5 of 5 Old 01-06-2006, 05:37 PM Thread Starter
RED107
The rear of the drive shaft has a cv joint in the rear of the shaft. The center was extremly dry.
Code:
RED107 is offline
Front drive line vibration 97tjeep TJ Wrangler Technical Forum 5 01-29-2010 07:18 PM
front drive line u joint?? Allen52105 YJ Wrangler Technical Forum 3 07-23-2009 05:17 PM
Drive Line Noise when Warmed up from extended drive amytom TJ Wrangler Technical Forum 1 02-26-2009 02:11 PM
RE belly plate and front drive line jays-tj TJ Wrangler Technical Forum 3 08-21-2007 02:25 PM
Front brake line size-Hard line?? learfxr YJ Wrangler Technical Forum 4 07-14-2007 07:24 PM
