#1 | |
front disconnects!!!
hey guys i'm having problems with my stock disco's.....i took off the bottom bolt and the top bolt...but how do i get the disco off....i think i might've messed up the thread on the top b/c now i can't get the nut back on.....help me out guys what do i do!!!
needing a new rig.... |
#2 |
The stocks aren't "Discos", they're designed to remain attached. Are you replacing them with after market disconnects?
Anyway, if the threads are messed up, either fix them with a die or clean them up with a small file. |
#3 | |
#4 |
now its completely cross-threaded and ****ed up!!! now i have to get some disco's for sure or something!!!!
#5 | ||
Disgruntled Jeepforum'er
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
You definately want discos. For now you can drive the jeep, but take it easy on the first few turns. It's going to feel like you're driving a block of jello.
-Ryan Google Voice (or the number Grape calls when drunk): 845-476-8182 Quote:
#6 | |
Autozone has free tap and die kits for rent. Im sure you could clean up the bolt good enough to get the nut back on till you get discos. Edit: You appear to be at my "Beer Point". When I get frustrated with something, instead of forcing it, I walk away and grab a beer. Usually the break helps me think it through. |
#7 |
the tops of those sway bar links are pressed in. you either need to use a puller or pickle fork to pry them apart. or I seen someone on here take the entire sway bar off and laying it on the ground, bolt threads down, hitting it with a hammer to get them to pop out.
RUBICON Tomb Raider #953 With a Few Extras... |
#8 | |
thanks for the help though.....whats a pickle fork??
#9 |
#10 | |
...haven't messed with it yet....but i definately wanna get some discos!!!! now i just have to get them sooner! my jeep loves me, its gotta b/c i spend so much on it!![]()
#11 | |
#12 | |
#13 | |
#14 |
is anything gonna mess up if i drive with them off until i can get some disco's....speaking of that i think i'm gonna get some JKS quicker discos are those pretty good??
#15 | |
02 2.5.L automatic: 4.0L t.b., 4.0l air intake, K&N filter, Scream'n Demon coil, 8.5mm MSD Super Conductor plug wires, Stage 1 Jet Chip, 29" BFG all terrain KO's. Taurus E-fan, Hummer front bumper, Skyjacker high capacity trans pan, 48" hi-lift, Rubi susp, 3/4" Daystar BB. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
