Send Message Advertisers Vendors Announcements
Jeep Forum Classifieds JeepSpace Reviews Gallery Blogs Clubs Groups Videos Wiki Links Events Articles
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Wiki Jeep Links Jeep Events Jeep Articles
Moto Alliance Viper Elite 8,000lb Winch Giveaway!
Go Back   JeepForum.com > Models > Wrangler Forum Group > TJ Technical Forum
Jeep Registry Register FAQ Mark Forums Read Search Members
Old 02-20-2007, 02:47 PM   #1
rob1525
Front Diff fluid change
So I finished up my read diff fluid change and moved to the front. It is a good thing that I tried removing the fill plug first cuz it wont budge. Anyone have an idea of what I should do? Maybe just take the cover off and deal with it then or what? Any ideas appreciated.
rob1525 is offline   Reply With Quote
Old 02-20-2007, 02:51 PM   #2
thesherm
if you dont have another cover and you can't get the fill plug off, dont take the cover off! you don't want to get stuck with no fluid and no way to refill it.
you could use this as an excuse to get a fancy new cover tho
98 Sahara
Originally Posted by mrblaine
Unfortunately you are one of those poor misguided folks that believes leaving the gear shift lever in one slot or another is an indication of control.
Come go for a ride and I'll be glad to demonstrate the difference between what you perceive incorrectly as "control" and what control actually is.
Pick a different reason because that one is both lame and stupid to perpetuate.
Pardon me for damaging your precious reputation. It's not that I disagree, that would be a difference of opinion. This isn't subjective, it's objective, you are just wrong. If you make that statement, you are misguided. It is that simple.
thesherm is offline   Reply With Quote
Old 02-20-2007, 02:54 PM   #3
rob1525
Good Call!!!!! Where would be the best place to check out?
Old 02-20-2007, 02:55 PM   #4
[ITA]Tsunami
Italian Wheeler in Mexico
[ITA]Tsunami's Avatar
Send a message via MSN to [ITA]Tsunami
I've seen the new diff covers from ARB...man! they look sweet!!!
[ITA]Tsunami is offline   Reply With Quote
Old 02-20-2007, 02:55 PM   #5
Crashnburn80
Smart. Its always a good idea to try taking the fill plug out first
As for your situation, I think it would be easier to torque on the plug with it bolted to your Jeep. If you take it off you will somehow have to firmly secure the cover to really crank on it and 2 if it doesn't come out you will be unable to drive your Jeep.
I'd just find a bigger wrench, or a pipe to put on the end of your current one.
Crashnburn80 is offline   Reply With Quote
Old 02-20-2007, 02:56 PM   #6
Crashnburn80
Northridge4x4 has a sale on Rockcrushers for cheap, and free shipping too.
Old 02-20-2007, 03:57 PM   #7
SecondTJ
cheater pipe/bar will work.
'00 Sport. 5-speed, Detroit TrueTrac Dana 44 rear, Detroit TrueTrac front, 4.10's, 2" RE BB, OME shocks, 31" BFG MT, JKS Quicker Disco's, Borla, Chicago Electric 10k winch
'99 Z28 M6, some goodies
'94 'Vette, A4 all stock
SecondTJ is offline   Reply With Quote
Old 02-20-2007, 06:48 PM   #8
Pipedrummer
throw a galvanized pipe onto the end of your breaker bar for more torque, you may have to jack up the jeep to get more clearance
maybe some PB blaster? not sure if that would be bad for anything if it works its way into the diff....altho you're gonna be changing the fluid anyway.
Solar Yellow '04 TJ Sport, RE 3.5" Standard Kit w/ GEN 2 Discos, 33x12.5R15 Cooper Discoverer STT's on Black Crager D Windows, OME Shocks and Stabilizer, LOD Xtreme Duty Rear, Jeeperman Front w/ Pre-Runner Bar, Viair Constant Duty OBA - Front & Rear Quick Air Discos, Firetruck Air Horn, Galls Siren w/ PA, CARR Rotabar w/ KC Long Range Lights & KC Driving Lights, KC Fogs, Superwinch 9000lb, Viking Synthetic Line, Optima Yellow Top
Pipedrummer is offline   Reply With Quote
Old 02-20-2007, 06:50 PM   #9
Muddeprived
Send a message via AIM to Muddeprived
yeah i second the pipe trick. If you have a hi-jack, there you go. Stick the handle over your socket wrench and it'll snap it loose in a second. Impact gun (with 1/2-3/8" adapter) would loosen it.
2001 XJ Sport 4.5" RC LA
Custom snorkel
Detours/winch
Flux Capacitor Heat Machine
Muddeprived is offline   Reply With Quote
First diff fluid change at 12K miles shadows_lair TJ Technical Forum 5 06-30-2008 06:06 PM
Diff Fluid Change ianschrd TJ Technical Forum 10 09-28-2007 10:03 PM
Front and Rear Diff. fluid change question... PiratECU23 TJ Technical Forum 10 09-07-2007 10:48 AM
Growl after front diff fluid change! jhattan TJ Technical Forum 42 06-06-2007 02:59 PM
Diff Fluid Change sdlemaster TJ Technical Forum 6 02-18-2007 08:59 PM
The time now is 10:06 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation.
JeepForum.com is not in any way associated with Jeep or the Chrysler Corp.
