Front Dana 44 Swap Help! - JeepForum.com
post #1 of 18 Old 12-21-2005, 08:14 PM Thread Starter
Nickb1907
Nickb1907's Avatar
Okay so the manager at 4wheelparts gave me this dana 44 out of the front of a rubicon. Its just the axle though - Inner knuckles, shafts, and Differential. it doesn't even have the diff cover. it was free, so im considering building this up.
my question is what can i use out of my dana 30 to put in this 44. Shafts, outer knuckles and brakes, Gears, carrier. I need to know what i would need to get if its not compatable with the dana 44. thanks
Nickb1907 is offline
post #2 of 18 Old 12-21-2005, 08:35 PM
blacktjsport
I have been researching axles and swaps recently and from what I have gathered, pretty much everything will swap over. The only real difference between the 30 and 44 front is the housing. Everything is the same and will swap over, shafts, knuckes, brakes and so forth. While upgrading you might wanna upgrade the u-joints to beefier units as those are usually the weak points in a 30 or 44 front. Might as well put some Warn hubs and chromoly shafts in too. With that setup you will good up to 40" tires depending how you are on the gas. Someone with more experience will step in Im sure. HTH.
--Matt
~~2000 Black TJ Sport~~
-Parts list keeps growing...
blacktjsport is offline
post #3 of 18 Old 12-21-2005, 08:45 PM
CRSMacgyver
Everything except the cover, gears, carrier, and axle shafts will work. We do these all the time, if I can help at all PM or call me and I will be happy to help you out.
Andy
www.carolinarockshop.com
704-525-5109
CRSMacgyver is offline
post #4 of 18 Old 12-21-2005, 10:19 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by CRSMacgyver
Everything except the cover, gears, carrier, and inner axle shafts will work. We do these all the time, if I can help at all PM or call me and I will be happy to help you out.
Andy
704-525-5109
slight change to help you out Andy.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #5 of 18 Old 12-21-2005, 10:37 PM Thread Starter
Nickb1907
Nickb1907's Avatar
One of my friends told me that the Dana 44 is exactly the same as the Dana 30 except for the differential, gears, and carrier....is this true? Does that mean that the tubes are not beefed up at all for the rubicons, or even the old wagoneer dana 44s?
also, it has no yoke(i think this is the correct term) for the front driveshaft, is that part of the carrier?
post #6 of 18 Old 12-21-2005, 10:38 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
asked and answered
I am Savvy
post #7 of 18 Old 12-21-2005, 10:47 PM Thread Starter
Nickb1907
Nickb1907's Avatar
Originally Posted by mrblaine
asked and answered
by this im thinking that you mean what he said is true and the tubes are not beefed up...
post #8 of 18 Old 12-21-2005, 10:49 PM
camoTJ
camoTJ's Avatar
I thought the stub shafts are the same as well.
( and a rubi 44 wont last with 40's )
1 tons 106" wb 40's....just like everybody elses
camoTJ is offline
post #9 of 18 Old 12-21-2005, 10:51 PM
UCTJ
UCTJ's Avatar
From what I know the tubes are the same....but you can still build it up pretty good and all...or you could just put a Super 30 w/an ARB up front get the Alloy USA shafts and add CTM u-joints now your D30 will be pretty dang strong, you dont have to jack with fabbing it up and you can always get a high steer knuckle to improve your steering geometry. And you can always make a few bucks by selling the 44 front...just another thought.
UCTJ is offline
post #10 of 18 Old 12-21-2005, 10:57 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
--Matt
Not even 37's on a steady diet of rocks with that be durable for.
I am Savvy
post #11 of 18 Old 12-21-2005, 11:04 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I have all three American front axles that bolt into a TJ in the back yard. LP 30, HP 30, and LP 44.
The only differences are anything that has to do with the pumpkin and pinion height above the ground.
Everything else is close enough to be interchangeable with the exception of different years of unitbearings and that's only because of the rotors needed. If you already have rotors and unit bearings that match, run 'em.
I just looked at the Rubi unit bearings and they look pretty darn close to the 2000 and up TJ units.
I am Savvy
post #12 of 18 Old 12-21-2005, 11:18 PM
camoTJ
camoTJ's Avatar
add hubs to that.... ctms dont like turning all the time
camoTJ is offline
post #13 of 18 Old 12-21-2005, 11:33 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Internet Myth. Not your fault, but call Jack at CTM to verify if you believe it to be true. In fact, it's a myth started by a buddy of Ox because they don't recommend theirs on a DD without lock outs.
I am Savvy
post #14 of 18 Old 12-21-2005, 11:53 PM
camoTJ
camoTJ's Avatar
Ineresting....Even from shops I have heard that. I will prolly run into jack at some point in the next year, maybe I will ask him. But I could see that to be true. Not like it really matters since I run hubs, but nice to have the right info
camoTJ is offline
post #15 of 18 Old 12-22-2005, 09:07 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Next time a shop informs you of that little nugget of misinformation, ask them where they got it from. Likely they have someone who spends time on the forums.
I am Savvy
dana 44 front axle swap for tj stacerbob TJ Wrangler Technical Forum 11 03-17-2009 03:07 PM
cj dana 30 front axle swap hurricane99 YJ Wrangler Technical Forum 5 01-01-2009 07:45 PM
Front Axle Swap, SJ Dana 44 HeepToJeep YJ Wrangler Technical Forum 1 01-31-2008 10:46 PM
Dana 44 front axle swap Kris B Krunch TJ Wrangler Technical Forum 15 08-18-2007 12:02 AM
Dana 44 front and rear swap into a yj? MeatPuppet YJ Wrangler Technical Forum 7 08-04-2007 09:56 PM
