Which front coils for 5.9 magnum swap - JeepForum.com
post #1 of 6 Old 11-11-2010, 08:00 AM Thread Starter
jpross
My brother and I did a 5.9L Magnum swap into his 97 TJ and now the front end is sagging like crazy. What coils can we swap into the front to lift it back up?
The current setup is...
front: 2006 rubicon coils with 2"BB (about 2" height between fender flare and tire)
rear: original jeep 2.5L coils and 2"BB (about 4" height between fender flare and tire)
We tried the v8 front coils from a ZJ but it made no difference at all compared to the front rubi coils.
What are your suggestions? We prefer junkyard swaps. Thanks
jpross is offline
post #2 of 6 Old 11-11-2010, 10:24 AM
pcoplin
That's odd, my front end sunk maybe a 1/2 inch, but I have aftermarket coils. I think it's only like 100-150lbs more than the 2.5.
You're not going to find much in the way of JY springs that will lift you more than ZJ V8 springs. I do remember something about F150 coils springs. DO a search on Google "Jeep f150 coils", that should get you some info.
FullStack MotorSports
pcoplin is online now
post #3 of 6 Old 11-11-2010, 11:01 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
The magnum doesn't weigh much more than the i6. Like 50lbs difference.
ratmonkey is offline
post #4 of 6 Old 11-12-2010, 05:31 AM Thread Starter
jpross
Now that I think about it, before I replaced the rubi coils on my jeep they were starting to sag just from the weight of the winch.
I have heard that the hemi weighs in at about 50lbs more than the IE6 and the hemi is 50 lighter than the magnum.
Looks like the best route to take is some heavy duty front coils. Pcoplin, what coils are you running?
jpross is offline
post #5 of 6 Old 11-12-2010, 07:33 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
try OME 934 fronts.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 6 Old 11-12-2010, 10:09 AM
pcoplin
I'm using some custom wound springs my buddy had made years ago. I wouldn't hesitate putting whatever coil you like, just make sure the rate is on the higher side. I would go with Currie or OME myself.
5.9l , coil spring , sagging , suspension
magnum engine swap Arcticcat843 TJ Wrangler Technical Forum 17 09-14-2015 01:35 PM
5.9L Magnum Swap? Diffcult? rastaangel TJ Wrangler Technical Forum 7 02-14-2013 07:06 PM
Swap a 3.9 magnum into the yj Russell_Goodall YJ Wrangler Technical Forum 18 10-28-2011 07:30 PM
5.2 Magnum swap question czjeeper YJ Wrangler Technical Forum 0 10-10-2010 10:31 PM
Looking into 4.2 to 318 (5.2) Magnum Swap lt_liverdamage YJ Wrangler Technical Forum 6 01-11-2010 10:35 AM
