Front Bumper Suggestions Stock TJ - Page 2 - JeepForum.com
post #16 of 19 Old 07-30-2012, 11:19 AM
et43011
Here's mine when I first bought it, unlifted with no winch... has the body armor front bumper
et43011 is offline
post #17 of 19 Old 07-30-2012, 11:44 AM Thread Starter
yocarney
I like the look of that stock bumper, might just cut the bend off mine. Where did u get that hoop? How hard is it to make one yourself?
yocarney is offline
post #18 of 19 Old 07-30-2012, 12:49 PM
esad_b
If you like the stock bumper with the hop from RowJ here is another stock bumper with the same hop only slightly modified
Its a Rugged Ridge bumper light bar, has 2 tabs behind it to mount the lights. I think its around $40-$50. I modified the base to raise it higher off the bumper to fit the winch on mine.
esad_b is offline
post #19 of 19 Old 07-30-2012, 02:00 PM
RowJ
I like the look of that stock bumper, might just cut the bend off mine. Where did u get that hoop? ....
Assume your referig to my pic?? If so....
- Removed the plastic "ends" on factory bumper (screwed on).
- Used a grinder with cutting disk to do the angle cut.
- Add Rugged Ridge Light Bar for $49.00...if interested.
RJ
RowJ is offline
bumper , stock , tj , weight
Front Bumper Suggestions Hatleyville454 JK Wrangler Technical Forum 4 09-12-2011 04:02 PM
suggestions on a front bumper akread TJ Wrangler Technical Forum 40 01-14-2010 03:46 PM
New Front Bumper Suggestions- Towing luk4mud TJ Wrangler Technical Forum 3 08-31-2008 08:25 AM
Hood & Front Bumper Suggestions HafellaFUSE JK Wrangler Technical Forum 4 05-27-2008 03:27 PM
Front bumper suggestions jayr TJ Wrangler Technical Forum 3 09-19-2006 11:23 AM
