Front bumper removal. - JeepForum.com
post #1 of 16 Old 09-26-2008, 06:02 PM Thread Starter
ArrizX
1997 XJ Cherokee
I have a T55 Torx 1/2'' drive and an air gun I am about ready to remove the hooks and drop the bumper so I can put on my high lift jack mounts.
But, I was told not to do it yet because if I do it wrong I could set off the air bags. So either I need to do it super careful and not with an impact gun, or I need to disconnect the relay or something like that. Do you guys have any advice as to what I need to do.
I will be doing this on both my, and my dads jeep. 99 sport, an '06 se both with airbags.
ArrizX is offline
post #2 of 16 Old 09-26-2008, 06:09 PM
Rubikahn
Rubikahn's Avatar
Mine came off easily with a ratchet with a piece of pipe I had laying around to act as a breaker bar. You may want to PB blast your 99 though and make it easier to remove the bolts.
Rubikahn is offline
post #3 of 16 Old 09-26-2008, 06:14 PM
BoatCop
Mine came off easy with a small breaker and my foot.
It's a 2001, but we don't have any problem with rust in the desert.
Alan
2001 Wrangler TJ
2009 Chevy Tahoe
2007 Ford Expedition (Work Truck)
1999 Fleetwood Southwind 34' MH
BoatCop is offline
post #4 of 16 Old 09-26-2008, 06:33 PM
DRZAP
I expected mine on my 98 to be stubborn. I bought 3 torx 55's expected to break a couple. They came with a snap of the breaker bar. I had not thought much about the air bags last winter I did some major over hauling with badly rusted bolts and never bothered the airbags. Good luck and go for it.
DRZAP is offline
post #5 of 16 Old 09-26-2008, 06:37 PM
default_user
It's a Roobicon
correct me if I am wrong, but isn't the airbag disengaged with the ignition off?
default_user is offline
post #6 of 16 Old 09-26-2008, 06:46 PM
Kiwi
There is nothing in the front bumper area even remotely associated with the airbags. It's inside the passenger compartment, just in front of the console.
I'd be careful though with using an impact on those torx bolts, you can strip them out pretty easily. Try first without the impact.
Kiwi is offline
post #7 of 16 Old 09-26-2008, 07:50 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
you wont set the air bags off, as stated the sensor is in front of consol under dash, plus air bags dont go off (from impacts) with ignition off
RnEmOvr is offline
post #8 of 16 Old 09-26-2008, 07:54 PM
lilboy1023
I would agree with everyone else. There isn't any sensors on the bumpers to worry about. Just channel iron. Don't worry about it. I would suggest doing your dad's first for practice!! LOL
lilboy1023 is offline
post #9 of 16 Old 09-26-2008, 08:08 PM
SuMeRiaN
SuMeRiaN's Avatar
Don't forget the two underneath ....
SuMeRiaN is offline
post #10 of 16 Old 09-26-2008, 08:13 PM
lilboy1023
Good advice.
post #11 of 16 Old 09-26-2008, 09:48 PM
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
I definitely would avoid using an impact wrench except as an absolute last resort. Those torx bolts are darn easy to strip out.
We save dogs:
JBWood05TJ is offline
post #12 of 16 Old 09-26-2008, 09:50 PM
XXRider
I have had those bolts out 5-15 times in the last few months, I always used a impact but I've got NO rust at all.
XXRider is offline
post #13 of 16 Old 09-27-2008, 01:14 AM Thread Starter
ArrizX
1997 XJ Cherokee
Thanks for all the information guys its really helpful.
Trust me, ive used ratchet handles, breaker bars and even cheater bars on my jeep, and just a breaker bar on my dads. I can get my dads, but mine are stubborn. Im going to set the impact gun to lowest setting and soak them in WD-40 and hope for the best.
ArrizX is offline
post #14 of 16 Old 09-27-2008, 05:06 AM
jeep06
jeep06's Avatar
2015 KL Cherokee
Go to Wally's and spend a few bucks on a can of PB blaster.... it will save you a lot of trouble and much better than WD-40 when it comes to rusty bolts. A nice coat of anti-seize on the bolts when you put it back together will make the job easy the next time around.
2015 Cherokee Limited (granite) 4x4, 2.4L, 8.4AN, luxury group, wireless charge pad.
jeep06 is offline
post #15 of 16 Old 09-27-2008, 09:14 AM
mudb8
want it rite or rite now?
mudb8's Avatar
I use a 1/2 imact driver and a BFH to bust em loose, then hit em with the air impact gun.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
front bumper removal SickSpeed JK Wrangler Technical Forum 4 05-14-2007 08:46 PM
Front bumper removal GW TJ Wrangler Technical Forum 5 04-20-2007 07:04 PM
06 tj front bumper removal -- d.mehrl TJ Wrangler Technical Forum 8 11-20-2006 08:32 PM
Front Bumper Removal RooRooTJ TJ Wrangler Technical Forum 4 05-04-2006 10:56 AM
front bumper removal? gtex TJ Wrangler Technical Forum 9 08-03-2005 02:57 PM
