Front Bumper Removal - JeepForum.com
post #1 of 5 Old 01-16-2003, 09:10 PM Thread Starter
AlRego
I will be replacing my front bumper this weekend. Any tips or advice would be appreciated.
AlRego is offline
post #2 of 5 Old 01-16-2003, 09:23 PM
HKP7M8
HKP7M8's Avatar
A good quality T-55 soket and a Long pipe to use as a bracker bar.
Its a realy simple task. 4 bolts on the top 2 on the bottom and one under each fog light if you have factry fogs. I just replace my front bumper on monday.
2003 Inca Gold Rubicon. Mostly Stock.
The P7 is the Hannibal Lecter of autoloading pistols
Caution: Pistol may torture, kill and eat other pistols.
HKP7M8 is offline
post #3 of 5 Old 01-16-2003, 09:45 PM
macb
macb's Avatar
plus, double check the fit of the new bumper before tightening
anything down, put in every bolt just half way to be sure it fits.
take before and after pics!
mods are good!
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah:
Bob Supplee:
or (405) 799-8977
Stu Olson's great jeep resource site:
macb is offline
post #4 of 5 Old 01-18-2003, 09:04 AM Thread Starter
AlRego
Thanks for the tips. I will try to install it tomorrow.
AlRego is offline
post #5 of 5 Old 01-18-2003, 05:00 PM
rkutzner
rkutzner's Avatar
I replaced my Torx bolts with Grade 8 regular bolts. Towing my Jeep behind the RV (bumper mounted tow bar) seemed to keep loosening the Torx bolts. Also, with a longer one on the one that goes through the round part of the frame up front, you can add a washer/bolt for extra strength. Can't hurt with the winch,either and only cost a few bucks.............yeah, Grade 8 is probably overkill.....
2001 TJ Sport
Everything SELF INSTALLED.
The Serious Stuff:4.5 RE LA, 35" MT/Rs, 4.88s, Super44 w/Detroit, D30 w/Ptrax, SYE, Tera 4:1, 2LOW & Rear Disks, AntiRock, Lotsa Skids (some homemade!), Nth Shock Shifters, Patriot 9500...and LOTS more !
rkutzner is offline
Front bumper removal. ArrizX TJ Wrangler Technical Forum 15 09-27-2008 10:29 AM
front bumper removal SickSpeed JK Wrangler Technical Forum 4 05-14-2007 08:46 PM
Front bumper removal GW TJ Wrangler Technical Forum 5 04-20-2007 07:04 PM
06 tj front bumper removal -- d.mehrl TJ Wrangler Technical Forum 8 11-20-2006 08:32 PM
Front Bumper Removal RooRooTJ TJ Wrangler Technical Forum 4 05-04-2006 10:56 AM
