Front brake lines for Currie 4" lift? - JeepForum.com
post #1 of 24 Old 09-21-2017, 11:38 AM Thread Starter
toximus
It looks like Savvy has stopped selling them.
Are there any premade lines that work good with this lift and flex?
toximus is online now
post #2 of 24 Old 09-21-2017, 11:42 AM
biffgnar
biffgnar's Avatar
OEM YJ hoses
biffgnar is online now
post #3 of 24 Old 09-21-2017, 11:44 AM Thread Starter
toximus
Originally Posted by biffgnar View Post
OEM YJ hoses
Awesome. I didn't know those were good for 4" too.
post #4 of 24 Old 09-21-2017, 11:47 AM Thread Starter
toximus
What's the crush washer size or part number?
post #5 of 24 Old 09-21-2017, 11:48 AM
biffgnar
biffgnar's Avatar
IIRC every time I've bought hoses they come with new crush washers.
post #6 of 24 Old 09-21-2017, 01:29 PM
Trevlaw
Just go to Napa and have them match your old washer.
Also, I opted not to go with oem yj hoses, instead Napa actually had hoses listed for a TJ with a raised suspension, and they happen to be four inches longer than stock. They weren't largely available, but I ordered them and used them. I like have the entire hose be a soft line instead of the YJ lines having the hard line coming off the caliper. I have Currie 4" springs and plenty of hose left with about 7" of downtravel
I want a J-Series
TJ Build:
Trevlaw is offline
post #7 of 24 Old 09-21-2017, 01:35 PM
biffgnar
biffgnar's Avatar
Differences that don't make a difference are worth nothing.
post #8 of 24 Old 09-21-2017, 01:36 PM
Trevlaw
They were also about an inch or two longer than YJ hoses and I was able to get them for the same cost, so there...
I want a J-Series
TJ Build:
Trevlaw is offline
post #9 of 24 Old 09-21-2017, 01:37 PM
biffgnar
biffgnar's Avatar
post #10 of 24 Old 09-21-2017, 01:41 PM Thread Starter
toximus
So... basically having the extra inch or two doesn't make a difference if you don't use it.
I ordered Raybestos BH38862 and BH38861 as I suspect that my current YJ lines may have casused the calipers to stick.
post #11 of 24 Old 09-21-2017, 01:42 PM
Trevlaw
I saw you change that...
I want a J-Series
TJ Build:
Trevlaw is offline
post #12 of 24 Old 09-21-2017, 01:44 PM
Trevlaw
I ordered Raybestos BH38862 and BH38861.
Maybe I will use it... In a couple years lol
I want a J-Series
TJ Build:
Trevlaw is offline
post #13 of 24 Old 09-21-2017, 01:48 PM Thread Starter
toximus
Right? I'm already excited to 4-link and outboard.
post #14 of 24 Old 09-21-2017, 02:05 PM
biffgnar
biffgnar's Avatar
Exactly. How much would you pay for a custom hose that had a couple more inches of length? I'm guessing not much but based on your theory you should.
Unless you go to a travel bias that is stupidly skewed toward down travel, the YJ hoses work just fine. Well, I suppose if you pointed the hard line coming off the caliper down you could create issues but if you did that you deserve it.
post #15 of 24 Old 09-21-2017, 02:06 PM
biffgnar
biffgnar's Avatar
Are we talking about the front or the rear?
